Question about LG DH30 GoldStar Dehumidifier
LG Humidifier Model # LHD30 does not run.
In trouble shooting this I found the compressor and fan ran if jumpered. I think the control module is gone. My search showes it to be a EBR39204301. This control module seams to be used in many units.
  • 210 Answers
SOURCE: Dehumidifier will not shut off
The auto shut off will work when you have your bucket in, as well when you have met the humidy level which you have chosen. Try changing the setting.
Sgt 48
Posted on Jun 04, 2008
  • 121 Answers
SOURCE: Unit runs a lot. Doesn't condense much water. Sometimes fan runs alone, sometimes compressor runs alone.
You may also want to check the coils and make sure they do not have dirt or dust on them. If they are clean you may have an issue with the refrigerant level which will cause the coils not to cool properly. For that you will want to contact LG. There could be an issue with the compressor also. LG backs alot of their models with a 5 year warranty. Contact them and let them know about your issue. Make sure you still have your reciept. Here is their contact number:
1 (800) 793-8896
Posted on Jul 08, 2008
bozcro
  • 867 Answers
SOURCE: lg LHD30 dehumidifier not producing water; fan and
there may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
Posted on Jun 24, 2009
  • 587 Answers
SOURCE: LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Posted on Aug 23, 2009
  • 4736 Answers
SOURCE: one-year old LG humidifier (LD450EAL)
Alan, it may simply be a case of several things, that can easily corrected at home.
1. The Humidity Extraction Level is set to High. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Remove, inspect the filter and clean if necessary. It it's a
Washable Filter, allow it to thoroughly dry before reinstalling it.
3. Obstructed Air Flow. A minimum of 12" to 18" clear air around the entire unit, must be
maintained.
4. The ambient air temperature at floor level is between 40 - 60 degrees F. This is particularly true in
basement applications. The air temp at floor level is colder than the air temp at shoulder level.
Dehumidifiers don't work well in that temperature range (Unless, it's a Low Temp model). Raise
the unit up off the floor on to a sturdy table, counter top, etc, that can handle the weight of the
unit, plus a full tank of water.
If you troubleshoot the 4 things listed above, it may quickly solve the problem. Please let me know. Thanks.
Posted on Jun 18, 2011
Our daewoo humidifier model dhc-250 date made 02/04 runs but seems like voltage goes up and down if on low or high fan and cont. cleaned all out ran great last year but now runs can hear power click up and...
Quite frankly, from what you described, you may need to have the refrigerant gas in the compressor drained and recharged. As. it sounds like the compressor wants to turn on, but lacks the ability due to low refrigerant or a faulty condenser switch. Either one can be repaired. But, if you don't have the experience to deal with it, it's best left to the pros.
Hope this helped you to troubleshoot and solve the problem.
Jun 21, 2011 | Daewoo DHC250 Dehumidifier
The compressor runs, but the fan doesnt work when we trouble shooted it. we found out it has power when we bypassed the switch and tested it. we pulled out the control box and it doesnt look like anything...
Hi, after reading you're problem, I found that you did the right thing.If you bypassed the switch and now you have power to the condenser motor but it doesn't operate, the motor is faulty, as you are eliminating the switch sending power to the fan motor. If you have power going into one side of the switch and you jumped it over, and the motor starts, the switch is at fault. So, you did the right thing! Sometimes you cant tell by looking at the switch wiring to no if it is at fault.In the field, we use jumper wires everyday to bypass components to check them out.In you're situation, both the compressor and condenser fan motor operate from this same switch, and the compressor was running. So, that tells me without having to bypass it that the fan motor is the faulty one, or the compressor would also be off. You may have to find one at a appliance parts house, or order one online. Sounds to me that you will have no problem changing this out. Best of luck to you, and Sincerely,
Shastalaker7
PS Let me no the out come.
Dec 07, 2009 | Kenmore 54351 Dehumidifier
4 - Wired wrong
Aug 07, 2009 | LG DH30 GoldStar Dehumidifier
Humidifier compressor does not stay on more than 1-2 minutes
Sounds like bad relay on compressor or bad compressor. There is only so far you can go yourself without knowledge in electrical and AC units. Suggest you call a service tech or if you can take it to service cemter near you. Russ
Jul 24, 2009 | Kenmore 5230 Dehumidifier
Lg LHD30 dehumidifier not producing water; fan and compressor both seem to be working
Jun 24, 2009 | LG DH30 GoldStar Dehumidifier
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Jun 17, 2009 | LG LHD45EL Dehumidifier
Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Apr 21, 2009 | Haier HDN305 Dehumidifier
Sgt 48
Jun 04, 2008 | LG DH30 GoldStar Dehumidifier
Kenmore model # 25800-25801 Error code E3 ?
You can try cleaning the humidity sensor, which is on a circuit board
housed in a nylon clip attached to the cooling coils.
The sensor is in a plastic clip, which can be opened up and cleaned.
Some report success. Didn't work for me.
I ended up rewiring the unit so that a 5v control
line from the lower relay board goes through the SPDT bucket full switch,
turning on the control board when full (so it beeps), but otherwise
enabling the compressor and fan. The fan and compressor
are controlled by relays, which are driven by a ULN2003AN
relay driver. I fed the empty side of the full bucket switch back into
the relay driver to turn on the compress and the fan on high.
I plan to put a dehumidistat in series with this control line;
now it just runs till the bucket is full. A Broan DH100W dehumidistat
is 20 bucks. Could also put in a rotary switch to control the fan speed,
but for me high is enough.
I think this machine is made by Goldstar for Kenmore and Delonghi.
Stuff is just made to break and through away these days, which is a shame.
Jun 03, 2008 | Kenmore 53701 Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
157 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
