Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Double image and colour
My screen suddenly has a double or triple image that each has a separate colour attached with it, in other words it seems to have a fuzzy double inage with red and blue outline.
  • Sony Master
  • 3,459 Answers
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
double image and colour - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 24, 2009
How do we stop printed documents from being smudgy with double/triple print all over the page?
There are 2 issues here
1 if regular paper (20lb) and you see the same image 2 or 3 times repeated down the page, you have a bad FUSER. it is a consumable. (this is called "ghosting")
2 if you are using paper other than 20lb you need to set the paper type to a heavier weight. This will increase the heat. I think it is a fuser problem unless...
if one colour is doing it, then change that colour cartridge.
Feel free to PM me if you have more questions.
Jan 03, 2011 | HP Color LaserJet 2600n Printer
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Hello
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Nov 22, 2010 | ZenithZ2541S 25" TV
Suddenly a curved line appeared in the upper left and lower right corner ....and words like "muting" and lower right words are doubled with a red virtual image....the main picture in the center is pretty...
Convergence problem---set uses two of the STK-392-560 convergence chips.
Both will have to be replaced and set adjusted with remote.
Total parts cost on EBAY under 25 dollars.
I can tell you what is involved.
see attached photo of typical convergence problem and typical convergence chip.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Samsung hdtv has a problem
this points to a convergence amp problem. in customer setup do you have and control or movement on convergence adjstment
Mar 25, 2008 | Televison & Video
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
Poor image being displayed
Hi guys
You will be looking at either repairing or replacing the Mainboard where all the colour processing is done.
Sep 27, 2007 | Dell 2300MP Multimedia Projector
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
266 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
