CDV Software Blitzkrieg 2 for Windows Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When the Menu screen appears an Error message comes up and shuts the program down
Anonymous
Level 2:
  • Expert 184 Answers
  • Posted on Oct 07, 2009
Anonymous
Expert
Level 2:
Answers
184
Questions
0
Helped
82192
Points
441
Uninstall and reinstall the game.
1helpful
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
1helpful
2answers
Won't boot up Blue screen message is error file ati2dvag
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
1helpful
My computer can't boot. I'm receiving an error message user profile cannot be loaded. I tried restarting the computer but the problem is still the same. Any idea how to fix it?
Hi brollydragon,
Welcome to FixYa! How is it going?
When did the problem start? Did it happen just recently?
Please try to do the following to resolve the problem:
1. Please try to boot your computer to safe mode. You can boot to safe mode by doing the following:
  • Turn off the computer. Turn on the computer then immediately start tapping the F8 key repeatedly.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Use the (Down Arrow) arrow key on the keyboard, scroll down to Safe Mode then press Enter.
  • Login to your User Name.
2. Use System Restore to restore the computer's settings to an earlier date:
  • Navigate to the Start -> All Programs -> Accessories -> System Tools.
  • Click on the System Restore program icon.
  • Click Next > on the Restore system files and settings window.
  • Choose the restore point that you want to use.
Note: Check the Show more restore points checkbox to see more than the most recent restore points.
  • Click Next >.
  • Click Finish on the Confirm your restore point window to begin the System Restore.
Note: Windows will shut down to complete the System Restore.
Hope that helps
. Thank you for using FixYa!
1helpful
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Error messages temporarily blocking our programs
Reset your TV to default settings through the menu, go from there.
1helpful
My computer starts to boot then once it is completed the a message comes up saying there is an error and then a blue screen comes up and reboots itself. THis continues and does not stop
When starting up, press the F8 key to catch the Boot Menu. Select the option to disable automatic restart on system failure. Boot and when it fails the Blue Screen will remain for you. Look near the top and see what file has been identified as the failure i.e. NV4_disp.dll. (Google the file name to see what program or hardware the failed file is associated with) Press and Hold the power button to shut down. Turn the computer back on and press the F8 key again to catch the Boot menu, and select Safe mode. If allowed into Safe Mode, try to go into Device Manager and either disable the failing device, or remove the associated program. If this doesn't work you can try to do a system restore to a date before this error started to appear. If you post back the file causing the blue screen, I can instruct you further.
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Explorer.exe Application error in Windows XP Professional SP2
hello ! what you should do put another HD then install XP the reason for this messages could be due to registry .
if you are getting the same messeges get another cd of XP
GOOD DAY
Windows won't come out, with message fatal error.
If its appearing in blue screen..mostly it may be because of your memory. chek your hard disk also with any checking softwares like NDD, or seagate softwares
Top CDV Software Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
