Question about LG 47LC7DF 47 in. LCD HDTV
When turning on the television it does not turn on right away, taking up to ten minutes at times. There is sometimes a poping sound coming from the back of the television.
    Problem Solver:
  • 10 Answers
You have a defective power supply, most likely faulty electrolytic capacitors on the power supply board. The board can be repaired, I fixed one for a friend, it took 2 new capacitors $0.90 each.
Posted on Dec 17, 2009
When i turn the heat up sometimes it takes a long time for the gas furnace to start ..why?
Watch your furnace when you turn the thermostat up...make sure to record everything that it is doing. If you have an induced draft, forced air system, then the heat sequence of order should go like this... Initial call for heat from tstat, Inducer vent motor turns on-pulls in the pressure switch, circuit board sends power to igniter whether it is spark or hot surface, then gas valve opens. Flame sensor senses flame, burner stays on, and blower motor kicks in to heat the space. If you notice any variance from this, then something needs to be checked by an HVAC Service Tech.
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
I have a 93 f350 with a 7.3 diesel engine. Sometimes it won't start, other times it starts right away. It is completely random. It is not a fuel or temp. issue I'm sure of that. If it does not start with...
sounds like your having a glow plug issue. you can buy glow plugs at most auto parts store for about ten bucks each. they aren't that hard to replace. you can remove them with a deep socket. they are located at each cylinder you can see them right from the top. each has a single thick wire connected to them. good luck leave a comment on your results.
Mar 17, 2010 | Ford F-350 Cars & Trucks
TV does not turn on right away it takes ten to fifteen minutes to get it to turn on.
Phillips has a reputation for faulty power supplies. Most likely there is a bad capacitor or a cold solder connection in your power supply which only works when it comes up to temperature.
Sep 23, 2009 | Philips 37MF231D 37 in. LCD Television
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Will not turn on
Have you tried a new power box they can surge sometimes and play up you should try a new one of them and see if they help
Jun 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Plasma tv
have 42in Magnavox plasma just over 1 yr old picture freezes
for about a minute still have sound then flashes off then comes back on does this about every ten minutes after the tv is on for
a while used to take hours before problem occured has always
done this
Jan 06, 2008 | Televison & Video
LG 47LC7DF 47 in. LCD HDTV Logo
157 people viewed this question
Computer Repairing
Computer Repairing
