Question about Venturer 3.6" Portable DVD Player
Black screens, set checked everything but can not
Black screens, have checked everything, online it states to check kill switch on base but can not fine the kill switch?
My product is a Venturer 6.2' Dual Screen Mobile DVD Player
  • 44 Answers
The only "kill switch" I am aware of is the switch on the DVD compartment door. I don't have your exact model but, on my model, this switch is activated when the door covering the DVD is closed and deactivated when this door is opened (kills the DVD spin and reading laser). Look for a small square hole in the DVD player deck and a corresponding raised piece of plastic on the DVD door.
Posted on Apr 18, 2010
I have a portable dvd venturer pvs 1262 / no manual for troubleshooting. when i plug in the ac adapter the red light turns on, then the green light turns on. but then will immediatly turn off. i can see the screen start to light up..but still no screen.. the dvd disc will not spin at all. can you give me any troubleshooting advise. or a site that can help me? thankyou in advance
Posted on Jun 18, 2010
Can you advise what I need to do to access my BIOS
hi Barry J Edwards try to clean the RAM/memory 1st or change it sames to me like a RAM/memory problem..
Sep 14, 2015 | Computers & Internet
How do I get a new solid state ignition. My crruent leaf blower is not getting any spark
Hi, most lawn mower repair shops either will have those in stock or can order them for you. Its a common item, or you can go to www.mtd.com and order it online. Before repalcing the coil, remove the kill switch wire from the coil, then check for spark again. you could have a defective kill switch.
Sep 24, 2010 | Yard Man Mulchinator QuickShift BlowerVac...
I replaced ignition coil on a Tecumseh Toro 20018 mower. It would not start without disconnecting green "kill" wire. Now what do I need to do - replace the kill switch? Is the kill switch located on the...
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Aug 12, 2010 | Toro Garden
1997 Suzuki TL1000S - no electrical power at all.
check kill switch circuitry its located near the start button asembly.
Sep 30, 2009 | 2001 Suzuki TL 1000 R
Husqvarna chainsaw no spark
Ignition systems on newer saws are a solid state all-in-one package. Disconnect the kill switch wire from the ignition pack to make sure that the switch isn't broken. Use a fresh spark plug to check spark with. An old one that is black inside is likely shorted. If still no spark, replace the ignition module. Use a piece of card stock to set the flywheel magnets to module gap, then tighten screws
Sep 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
N72 data base corrupted
hi
u have just restored the phone to its factory settings
but if you do not mind losing data on the phone then you can try a hard reset
* Switch Off the device. * Press and Hold down the keys Green/Talk + 3 + *. * Switch On the device. * If everything goes well then you will see "Formatting" screen. Note: Please make sure that your device is fully charged before you proceed with formatting the device. If the battery goes down during this procedure, It may result in inconsistent state of your device.
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Nokia N72 Cellular Phone
92 Cb250 Nighthawk won't start
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
A “very helpful” rating for this answer? Thanks!
Jun 17, 2009 | 1992 Honda CB 250 Nighthawk
Can't open windows, computer screen has
bad onbord video need new video card ok if uuse atoi make sure pluged in u will have to go out buy new one that one toooka crap ok they do gota have cpu dusted out ever 2 3 mo gets to hot kills vvideos cards ect best to buy new one just video card
Jan 30, 2008 | Computers & Internet
My labtop is on but the screen is black, it is an HP Pavilion dv600
Hold down the power button unit the machine is totally off then reboot. If the screen appears then and boots normally then change the power options and set the monitor power save to off or longer. If still no screen display then there are three other possibilities.
  1. At the base of the laptop screen there is a little hole with a switch inside that switch maybe be stuck down using a small flat blade screwdriver lift switch but be very careful
  2. The monitor data cable loose or fallen out there should be a access panel at the base of the screen to open and check this.
  3. The monitor is faulty and will need replacing
Thanks J
Jan 20, 2008 | Computers & Internet
Help
If the monitor was dropped, most likely you damaged the internal components that provide the picture, whether LCD or CRT. Try connecting it to another computer. If this doesn't work, check the monitor's display settings or operating system display settings for contrast or brightness. NEVER open up the monitor, because there is a high voltage capacitor that stores voltage even when the monitor is off and could kill you if it discharges.
Jun 11, 2007 | Envision EN-7220 17" Flat Panel LCD...
Televison & Video Logo
359 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
