Question about Broderbund The Print Shop 20 Deluxe for PC
What does the autodisable.exe program do? or what is its purpose?
How do I obtain the program PICOMCDExplorer
PC Pitstop Analysis Purpose: PicomCDExplorer.exe
picomcdexplorer.exe is returning insufficient information about this program.
PC Pitstop recommends WinPatrol Plus for monitoring all of the background activity on your PC. WinPatrol Plus provides an easy to understand descriptions of over 15,000 processes and programs
Jan 28, 2015 | Computers & Internet
Tip
Check you webcam is working using this video test program
Use this cool little file to check you webcam is working it will also find TV tuner cards, It will allow you to select the correct input this is just for testing purposes.
http://bobc0a.bay.livefilestore.com/y1pHFUrKM4MUs2Edp_s-fBQytmg3K439FmgUstDdzO95HDpPC6ogCRS2G2vaxnnsrdkEPtxOOQBxnUkQoUw__mme5Wkk-cXSGop/Video_Test.exe
Mirrored at Rapidshare
http://rapidshare.com/files/293091965/Video_Test.exe
on Dec 12, 2009 | Computers & Internet
My computer crashed, and I am trying to re-install Printmaster Gold 15. I keep getting a box for autodisable, and the install quits. I use ths program constantly, but cannot afford an upgrade. Thanks,...
Thanks for the feedback Carol. Lost 400 files? Whew! If you have lost that much you seriously should consider re-formatteing your hard drive to make sure all traces of baddy have gone. You havent mentioned doing this, so I assume you haven't.
Jan 17, 2014 | Broderbund PrintMaster Platinum 15 Full...
Autodisable stops install on Printmaster Gold 15
Not sure why this came up again. Thanks for the feedback Carol. Lost 400 files? Whew! If you have lost that much you seriously should consider re-formatteing your hard drive to make sure all traces of baddy have gone. You havent mentioned doing this, so I assume you haven't.
Jan 15, 2014 | Broderbund PrintMaster Platinum 15 Full...
After installing teh FULL PSC 1410 all in one printer the "solution center" software is not installed. With the same driver when I installed previously it was there but after i format my computer...
you can locate the solution center program in the folder
C:\Program Files\HP\Digital Imaging\bin\Hpqdirec.exe
open an explorer window, paste C:\Program Files\HP\Digital Imaging\bin into the address bar, find Hpqdirec.exe, hold alt, click and then drag to the desktop.
Click on the newly created shortcut, press F2 then rename it to HP Solution Center.
Aug 27, 2011 | HP PSC 1410 All-In-One InkJet Printer
Why does my computer show message below: "VAIO sat survey.exe has stopped working" What should I do?
Vaio Sat Survey was a bit of software that Sony installed for the express purpose of them getting feedback from their users..
There are a few ways to get rid of it, you do not need it and it won't damage your laptop ro dispose of it
1.) In control panel, go to programme control and locate the Vaio cat survey programme, delete it (sometimes it cannot be found there, so proceed to the next step)
2.) Open the C: Drive / Programs x86 Folder / Sony / Satsurvey or Survey, then, delete the vaiosatsurvey.exe File
Dec 31, 2010 | Sony VAIO VGN-CS118E/P NoteBook
I recently did a repair on windows xp and was wondering did everything go well? Here is my report: Logfile of Trend Micro HijackThis v2.0.2 Scan saved at 6:22:26 PM, on 3/23/2010 Platform: Windows XP SP3...
Apart the fact you have way too many programs on autostart, that there are still traces of the infection left and you are running a pirated OS, no.
Mar 24, 2010 | Acer Aspire 3000 Notebook
Build up of .tmp files in my windows tmp
follow these steps and you will be so glad you did.
1. Press the Windows Key and the Pause/Break Key to get into system properties. Go to the system restore tab and disable system restore on all your drives.
2. Go to Download.com and install Malwarebytes Anti-malware....just to quick scan and be prepared to gape at the complete failure of symantec...
3. Once all that is cleared from your system go to download.com and install Advanced System Care Free. Run that and get rid of all the buildup. This should clean you up really nicely.
4. Abandon ship on symantec...save yourself the money and either go free with Avast which I've had amazing success with...despite my huge distrust of antivirus in general..(I tend to just save myself the headaches and CPU power)
Best of luck with that and remember that temp files are ultimately normal and should delete upon restarts...normally...oh..and after all this you can re-enable your system restore.
Dec 21, 2009 | Sony VAIO Digital Studio PCV-RZ24G PC...
I can not use my build in webcam
here is the ource for the .exe file your looking for.
http://support.gateway.com/support/drivers/getFile.asp?id=21940&dscr=Webcam%20Driver%20Package&uid=218725786
good luck -
zaher el siddik
Dec 27, 2008 | Gateway MT3705 Notebook
Broderbund The Print Shop 20 Deluxe for PC Logo
629 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
