Question about Costar DYMO DiscPainter Printer
WHEN I PRINT ON THE DYMO DISCPAINTER THE IMAGE SKEW, PRINT CORRECTLY AND OUT OF PLACE
2 Suggested Answers
dj_relly999
  • 4070 Answers
SOURCE: Dymo discpainter will only allow
Hi! As a first course of action please unplug the discpainter from power source. Leave it unplug for 5 mins. then plug it in again. Turn it on and see how it goes. This should reset the system and may work normally again. Hope this helps and have a good one!
Posted on Aug 16, 2010
My dymo 450 turbo prints only 1 label even i order to print 10 labels. I use mac(10.11.5) and dymo label(8.5.3). updated last version.
Double check that your using correct printer driver.
Completely remove restart computer with printer discontente,then reinstall the printer.
Jun 29, 2016 | Dymo LabelWriter 400 Turbo Thermal Printer
My dymo 4000 prints in mirror image,how can I solve this?
You have the option to select which image to print when you go into the print screen. If mirrow image is marked, uncheck it.
Feb 16, 2015 | Dymo Office Equipment & Supplies
A print job queue is preventing other print jobs from printing
a print job in the print queue is preventing other print jobs from fixed printing
Dec 30, 2010 | Costar DYMO DiscPainter Printer
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
HOW DO YOU CORRECT A SKEWED COPY ON THE COPIER? HAVE CHANGED REGISTRATION ROLLERS, SKEW IS SAME FROM ALL TRAYS & BYPASS. TRIED ADJUSTING THE FOCAL LENGTH ON THE MIRRORS, AND STILL HAS ABOUT 1/8 INCH...
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Nov 18, 2009 | Ricoh Aficio 1018D Copier
I have missing strips when printing. Can this be fixed?
If you mean that there is a consistant blank area running though the image down the length of the label, then it could be a couple of things.
If it's just in one place there may be something stuck on the printhead (eg. if you had a label jam and it broke up on removal there may still be a bit lodged inside).
Or it could just be that the print head is dirty and needs cleaning.
Assuming you didn't have a messy label jam just before the problem started the most obvious next step is to clean the print heads.
The more recent printers come with a cleaning card in the box, but if you lost it or never had one you can buy them here:
Dymo Labels (UK)
(right at the bottom of the page)
If that doesn't work you could call dymo tech support on 020 7341 55 29 (uk) to see if they can suggest anything. If it's still under warranty Dymo will replace it if the tech support confirm it's a fault.
Sep 25, 2009 | Dymo LabelWriter 400 Thermal Printer
Does a DYMO Letratag QX50 have a replaceable ink cartridge?
Yes, DYMO Letratag QX50 ink can be purchased on amazon, click here and take a look Amazon com DYMO Letratag QX50 refills. I hope this was helpful, cheers
Sep 18, 2009 | Dymo LetraTag QX50 Thermal Label Printer
DVd label
All document printers with disc printing capabilities suffer from disc feed problems. It is an inherent design flaw that results from the machines original design to print documents. Loading discs to be printed must first "go around" the printer's paper feeding mechanism to accept discs. I got tired of using document printers to print labels on discs. I switched to a DiscPainter made by Dymo. It is a dedicated disc printer that was designed as such from the outset and not as an afterthought. It prints every bit as well as any document/disc printer but without the frustrating mis feeds. Although the Canon printer is great for documents its design limitations for disc printing are not easily overcome.
Feb 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Costar DYMO DiscPainter Printer Logo
120 people viewed this question
Top Costar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Costar Office Equipment and Supply Expert? Answer questions, earn points and help others
