Question about Roper REX4634KQ Electric Dryer
Dryer starts only with putting pressure unevenly on dial. start button pushed doesnt turn on
    Problem Solver:
  • 17 Answers
Space between the terminal and the push button is stretched. Open the switch panel and fix the distance.
Posted on Oct 07, 2009
My GE Dryer Model #DJXR433EG1WW will not turn on. It will not turn on and the dials don't turn right.
It sounds like your door switch is not closed. This switch has to be closed in order for power to be available at the start button. Open your door and manually push the button in and then carefully push your start button provided you have turned the timer on. If you are handy you can by pass and jumper out the door switch. The other possibility is if you can hear the motor quietly start when you push the start button your belt may have come off the pulley and the motor is just spinning.
Oct 12, 2014 | Dryers
When I turn the dial on my dryer to preset drying time and pushed the button the dryer started and ran but after a half hour it was still at the same location as I had put it and the clothes were stil
Sounds like the dryer fuse-able link has opened. If this happens the timer will not advance and the heater will not go on. Check the schematic of the dryer to see where it is located. When located check the continuity, if open, that is your problem. They are located in places that are not easily accessible (usually).
Sep 21, 2014 | Dryers
Dryer wont start just clicks what can be wrong
may be a bad thermal shut off , any error codes like F1 may also want to check ur push start button or dial with a multimeter, if its bad can get a buzzing and maybe a clicking
Sep 15, 2014 | Dryers
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
My gas dryer doesnt want to start. I push the start button and doesnt turn on. I checked the outwlet box were it is plugged into and it works because I connected a lamp it turned on. So I took apart the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Dryers
It's a gas dryer, just dried a load fine put in the next set the heat dial shut door and pushed the start button, nothing happened.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Kenmore Dryers
Dryer doesnt run when i push the start button light inside comes on when i open the door but nothing happens when i go to start it
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
43 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
