Question about Poulan Garden
Spool cap struck
I tried both directions to get the end off to respool with string and it is stuck what do i do
  • 437 Answers
Well you are going to have to cut off the cap off the get to the bolt head inside the cap. Use a hacksaw to cut downward to cut off the cap, this will get you to the bolt head. Depending on the color of the cap will determine whether it is a left threaded bolt or right threaded bolt. Red means left turn clockwise to remove, black means right turn counter clockwise to remove.
Good Day
Posted on Oct 07, 2009
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Jul 08, 2011 | Black & Decker String Trimmer Cordless 12"...
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Possible Line-Feed Problem
The notches are there to hold the line in place while you place the spool back on the trimmer. If you look at the spool, you will find, on one end or the other, an arrow showing direction to wind the string. Follow the direction and when you get the spool full, place it into the notch. Leave about 6" sticking out and cut it off. If you have a two string spool, just wind the other string as you have done the first. When you have both spools full and the ends in the notches, place the spool on the trimmer. As you start the spool on, place the string (or strings) in the respective holes. As you seat the spool pull the string that is the farthest in until it comes out of the notch. Do the same with the other string. Seat the spool and try your handiwork. Good luck...Lee
May 28, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
How do I load string in a P2500 string trimmer??
Remove spool by firmly pulling on tap button. Cut two pieces of line (0.080) about 12 feet. Insert the two ends of the line into the small holes inside the spool. Wind the lines evenly and tightly on the spool. Wind the string in the direction of the arrows on the spool. Push the lines into the notches on the spool leaving three or five inches hanging there. Insert the two ends in the two holes in the hub. Align the notches on the spool with the holes in the hub and push it in until it snaps into place. Pull on the lines to release them from the notches.
May 03, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
How to respool an electric Weed Eater Trim and Edge RTE 115
The nylon string is simply spun onto the emty spool. There should be an arrow on the top of the spool indicating the direction to wind the line. If the spool is missing a notch to hold the line to get started, use your finger to hold it in place for a few full wraps.
Apr 03, 2010 | Garden
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
How do i respool the line
Align the arrows under the bump feed, push in on bump knob, unscrew in counter clockwise direction, remove spool. Wind string in direction arrows advise on the spool, reassemble. You will be back to weedwacking asap.
Jul 05, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
How to string a st3812b string trimmer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 26, 2009 | Garden
Adding trimmer line to spool on husqvarna trimmer-two strings
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 19, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
156 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
