Question about HP PSC 2355 All-In-One InkJet Printer
Stops printing suddenly without reason
I have an All-In-One Hp PSC Printer 2355, it will stop suddenly printing without notice. I have reinstalled the application and it continues to stop. After investigating it shows that it has been placed Offline. Once I unplug the machine and restart it will shoot out two pages and the third will stop suddenly as if it is in a jam. Can you help?
sandrew
  • 2961 Answers
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
JULIANFIX
  • 975 Answers
SOURCE: psc 2355
check if there is a back door where you can access from there the rollers and check for any paper stuck , turn on printer and go to DEFAULT setting on the menu . hope it works
Posted on Apr 19, 2008
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Sandy4u
  • 107 Answers
SOURCE: Installation of HP PSC 2355 Problem
Hi ,
if u want prosiger for installation of psc 2355 please follow the steps
  • frist u remove printer usb cable from CPU
  • uninstall all drivers & software of printer withc u try ...
  • insert installation cd in rom
  • start installation & follow the steps .
  • it will get massage looking for new hardware or please connect u r printer
  • please connect u r printer in online
  • make sure u r printer is power on before u connecting to u r CPU
  • it will get recocnised u r printer follow the instructions
  • get finish installation.
check in printers it will be install or not ...
if this information is useful for u please Rate me.............
Posted on Jun 18, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
HP PSC 2355 print cartridge not supported?
If this is not a factory new cartridge then that may be the reason it is giving this error.
Apr 17, 2017 | HP PSC 2355 All-In-One InkJet Printer
I am getting the Error:0x88052ce6 and it starts printing and stops in the middle.
Remove cartrdiges, usb cable & power cable wait for coupple of minutes, gives power wait until cartridges missed message appears, load cartridges, wait for ewady mode, connect USB cable shoot print comman..
If error presists submit in service center..
Feb 02, 2012 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 is stopping in the middle of printing. Then can't even get it to turn off. message )xb984489d and 165 hw interrupt_hwv2.c Can you help?
Just fixed a HP PSC 2355 that had this problem. Turned out it was caused by dried out electrolytic capacitors on the printer circuit board. You can check it yourself by carefully removing the plastic cover around the power / USB connectors and then blowing warm air in to the opening with a hair-dryer for a couple of minutes. If everything's working now, you probably have faulty capacitors. Exchanging them is another matter entirely, don't attempt this unless you have a good working knowledge of electronics!
Mar 31, 2011 | HP PSC 2355 All-In-One InkJet Printer
I installed a refilled HP 94 cartridge in my HP PSC 2355 All-in-One printer. It worked well for several weeks but then I suddenly got the following Error Messages: "Incorrect Cartridge - Black ink...
This is a firmware issue with this printer model, and is fairly common. Try the following: remove both of the print cartridges, close the lid, wait for any noises to stop, and pull the power plug out of the back of the printer while it is still on. Wait at least 10 minutes with the cord disconnected. Plug the power back into the printer, wait for the noises to stop, and then reinstall the cartridges, black first (very important), and then the color. This will force the printer to reload its ram memory and should take care of the glitch. Let me know if you need further assistance, as I would like to be sure your problem is fixed.
Sep 30, 2010 | HP PSC 2355 All-In-One InkJet Printer
PSC 2355 All-In-One InkJet Printer: MY HP PSC 2355 printer is printing slow...
Please perform the steps below and check
1. Right click on My Computer and go down to Properties.
My Computer is usually on your desktop or in the Windows Start menu. Click on the Advanced tab at the top of the screen.
2. Under the Performance section, click on Settings.
3. Click on the Advanced tab.
4. Under Processor scheduling click on Background Services. Click on Ok then Ok again.
If the issue still persists please get back to me with the Operating System of the computer
May 18, 2010 | HP PSC 2355 All-In-One InkJet Printer
Why does my printer hp psc 1400 series stop in the
My printer will not print any docment i think that privter drive probablly need to be reinstalled.
Oct 28, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP 2355 will not print with Apple Air port.It would before, but not now
Try delete and reinstall your driver for the printer especially if you have connected the print to your computer with the USB cable before.
Sep 21, 2009 | HP PSC 2355 All-In-One InkJet Printer
Need to reinstall my HP 2355 printer
i lost my desk.. i need help to reinstall my hp 2355v psc all-in-one printer..
Jul 12, 2008 | HP PSC 2355v All-In-One InkJet Printer
HP PSP 2355
Jun 24, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
