Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Ammana Fridge-Evaporator Fan not working
Quoting a previous post
""I have an Amana Refrigerator model SCD22JL. The evaporator fan will not run. I checked the fan motor by applying current using jumpers and the fan motor will run. I used a volt meter to check the power to the motor. I have 115 volts on the yellow wire but the Brown wire is an open circuit when I check it to ground with an Ohm Meter.
I have narrowed it down to either the defrost thermostat or the defrost timer. Any thoughts?"
Now for mine....
I had to replace my evaporator fan as it was bad. But now that the new one is in, I have the exact same problem as the post above. With the new fan, I can ground out the brown wire and the fan will run. So I replaced the bi-metal/thermostat thinking it was bad. I wired it in the same way the old one was wired, and the fan still will not run once the coils freeze up. What gives?. What else is there in this circuit that could be bad that's keeping the new evaporator fan and thermostat from working?
  • TimDuce Oct 07, 2009
    How can I check that? I'd rather not buy anything else I cannot prove is bad. How can I prove the timer is bad?
  • TimDuce Oct 09, 2009
    Well that rules out the defrost timer. Since I've already replaced the thermostat, its not that either. I've even checked the new thermostat with my meter and it closes after it gets cold. So both Fan and thermostat are good. What else?
    I still have a hunch its the defrost heater, since one side of the defrost thermostat is wired to that component (the other goes to the fan). If that heater element is bad, would that prevent current from reaching the fan? Would a continuity check of the heater element tell me anything?
  • Amana Master
  • 1,606 Answers
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Posted on Oct 07, 2009
  • Mike Smith
    Mike Smith Oct 09, 2009
    Your timer cannot be bad , if the coils frost . The compressor will not run , if timer is in defrost . The defrost thermostat is what operates the fan motor .
  • 31 Answers
Your defrost timer possibly
Why amana fridge ABB1924WES freezer works refridgerator doesn't?
Check for a failed evaporator (cooling coil) fan motor or iced up evaporator due to a failure in the defrost timer, thermostat, or heater.
Jul 26, 2014 | Amana ABB1924WES 19 bottom mount...
Amana fridgerator model bx21vc
First of all you did the right thing by putting all information in print, ,any don't , Any ways sounds as if some thing was loose, And sounds like it needs more Freeon
Aug 27, 2013 | Refrigerators
I have an Amana BX21VW refrigerator and both the freezer and refrigerator stopped cooling. The fan is still going and there is power, but no cooling of any kind. What is going on?
Hi!!
Check
Temp. control knobs,
Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Amana Refrigerators
Refrigerator failed keeping food cold, ice maker stopped working
i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Nov 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerator warm but freezer is fineChanged the evaporator fan (12013211q)for BR18Ve Amana...Is it possible that the part last only a couple of years...
If your bottom freezer has ice build up, (you will see it frosted up), you do not have proper air flow. Check to see if your defrost elements are working. They are in the freezer compartment. in the evaporator. There is a defrost timer on the bottom of your fridge. You can turn the knob until the refergerator turns off, then listen in the frezzer compartment to se if the elements are working. (You will hear them sizzle)
Aug 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Amana SCD22JL
It sounds as though you have a refigeration problem if there is no cold on the coil, however you hav sad that you have changed the sensor which would bring in the fan when cold enough. As far as airflow I have been doing this a while on American cabinets and never really consider airflow as a primary failure. If the fan is running and the vents are clear that is normally enough, these fans are not high powered and the cabinets have a large volume. What you could try is leaving the door open whilst observing the coil and see if it frosts right through the coil without the fan running. If it does then it should pull down to temp. Hope this helps, unfortunately without seeing things its hard to give a definitive answer.
Aug 17, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Aug 14, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
648 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
