Question about Dryers
The dryer will not start. I ck the fuse ok. I have power everywhere except behind timer, the purple wire has nothing the red and white wire nothing and the white and black wire noting???????????
    Problem Solver:
  • 17 Answers
Check your main braker panel or plug in for the dryer.
Posted on Oct 07, 2009
Maytag gas dryer model SDG4606AWW timer wont rotate on any cycle, dryer just keeps running until knob is rotated manualy to off, replaced timer and new one is doing the same, took dryer compltley apart,...
I don't have a Maytag schematic handy but there should be one on or in the dryer. Trace the clock wiring back until until you get voltage. I am betting one leg of the time motor goes to the drum motor (Gray wire maybe) and the other leg to the dryness sensor module (brown wire). Check these wires against both Line and Neutral. That should tell of it's the module or the motor block.
Nov 04, 2013 | Maytag Dryers
Tip
Whirlpool or Kenmore Dryer Does Not Heat
Electric
First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
Gas
On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
Electric Dryers
NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
on Apr 17, 2010 | Dryers
Troubleshooting m460g timer
you should have power across the two wires to the timer while it is running . Power needs to be on the timer for it to work. One wire should be low ohms to the ground or metal surface and the other wire should be the power wire to the timer motor. if no power on the other wire to timer follow it back and you may find an open in a door switch or temp switch. good luck
Nov 04, 2013 | Maytag Dishwashers
Drier works but doesn't get hot heating coils look ok.there is a white thing with two wires going to it that has continuity.there is also a thing that looks like a black circle with 2 big red wires and...
These 2 things your describing are they on the housing where the heat element or the housing where the lint filter is??
i suspect they are the housing where the lint filter goes and the white on is the thermal fuse and it is good because it has contunuty on it (if it were bad the dryer would not start) the one w/4 wires is the cycling thermostat annd it too is good...the red wires will have continuty and the purple wires will not.
NOW THEN WHAT YOU NEED TO CHECK is the heat element for continuty AND both of the thermostat on the housing where the element fits BOTH t-stats on that housing should have continuty.
GENE
Sep 06, 2011 | Roper Dryers
My dryer was working just fine this morning and tonight we went to dry some clothes and it is doing nothing, I can hear the timer ticking so it is getting power, but it is not doing anything else.
I would ck the plastic door switch than ck the small white thermal fuse in back of dryer behind the large panel. You'll have to remove about 9 1/4 hex head screws to access.
Nov 10, 2009 | Whirlpool LER5636P Electric Dryer
thermostat would not cause it not to run if the white thermal fuse has continuity ck the door switch to be sure lever is not broke also ck breaker after switch timer most logical but unless you know to ck best not just guess could be expensive
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
Thermal fuse
with a volt ohm meter ck for continuity ..or unplug connect the 2 wire ends together and reconnect power turn on and ck..but be sure to ck vent system first for blockage before replacing fuse..but could also be bad door switch or timer
Sep 16, 2008 | Whirlpool LER5636P Electric Dryer
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Electric Kenmore Dryer
possible bad timer but first ck thermal fuse ..if top mount filter remove back fuse is small white object on blower housing ..if door mount filter remove bottom panel remove lint screen remove 2 screws each side holing lint screen housing in place fuse is behind it ..if fuse cks good suspect timer ..
Sep 07, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
