Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Saw won't work?
Took it to Boyd's Pro-Tac in Greenwood BC and when I got it back
it would start and run, but chain will not turn. When I tried to take the
cover off it was hard to remove, and will not go back on. Not sure he
knew what he was doing or did not care. Anyway there seem's to be a
ring that goes around the clutch and won't. Could it have been damaged
or twisted bad enough to cause this problen and can it be replaced, as saw is a good one.
    President:
  • 2,220 Answers
He set the chain brake before he returned it to you. That is why the chain wouldn't turn. Always grasp the forward most upper handle and pull it aft as far as it wants to travel before removing the clutch cover.
Reset Chain Brake
Please follow this link, cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button.
http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain HTH
Lou
Posted on Oct 07, 2009
  • dontbother10
    dontbother10 Oct 07, 2009
    The band (ring) on the clutch cover (cover) is the chain brake. It was tripped when you removed it. That is why it was so difficult to remove the cover. The brake (ring) must either be reset (per the above link) or replaced.
    An IPL (exploded parts list) for your saw can be found here:
    Poulan.com
    http://www.ordertree.com/modelinfo/POULA...
    There are a type 1 & 2 (2375LE) with different part numbers and item numbers, both are $19.43. A new clutch cover may arrive with the chain brake tripped and require resetting in order to install it. Before you spend any money take the saw and the loose clutch cover back to Boyd's. Ask him to reset the brake and demonstrate the proper use and resetting of the chain brake. He did nothing wrong!!!
    You can respond with questions in a comments block below the adverts.
    Lou
    This answer is complete and I cannot close it because I've already answered it once. I need a little outside assistance from a different moderator.
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
May 25, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
Jul 01, 2012 | Homelite Garden
Poulan P3216 chain saw - motor runs but the chain won't move.
Sounds like the chainbrake is on,grab the hand guard and pull it firmly back to the top handle until it clicks off.
Aug 14, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My 18" Poulan Pro Wild
Sounds like your chain is to tight.Take the cover that is at right side of the saw motor off and loosen the two nuts a bit and look for a tension screw behind the bar and back it off,if the bar won't move loosen the two nuts that hold the bar on the saw.With the saw siting like you use it pull down on chain and get about 1/8 of an inch between the bar and chain.(use gloves)If the bar is blue by the chain groove You will need a new bar.Blue means the bar has over heated and lost its temper.The blue metal is brittle in other words.You should all so check the drive sprocket for wear.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. Thank you for choosing FixYa.com and good luck.
May 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan pro model 4218 got caught in stump I was trying to cut down. Bar was bent. Went to box store where I bought the saw and bought "POWER CARE" 18A replacement bar and chain, brought it home and...
Try the easy solution first and post back if this does not solve the problem:
Insure your chain is on the teeth of centrifugal clutch sprocket correctly. It is easy to have it either on the inside of the sprocket or on the outside of the sprocket. If it is not on the sprocket teeth, it will not turn the chain.
Sep 29, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
The saw starts and runs on fast idle but dies when you use the throttle? it,s a troybilt 18in saw
It sounds like it is flooding when you use the throttle, both are connected. Turn the idle back all the way until it dies, then try turning it a 1/4 turn the other direction.
Feb 19, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain will not turn
take it back sounds like you have stripped the drive gear
May 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
107 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
