Question about Emerson Keyed .5hp Fullrate 115/230v
Pump clicks bunt wont turn on. touch the pupm feels hot and smells like something burning. im assuming that the pump is bad
  • Emerson Master
  • 8,404 Answers
Probably start cap needs replacing ...
if you are going to do that ... be very careful as this electric component stores lots of electricity.
Posted on Oct 07, 2009
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Rattling sound and burning smell
im not a dishwasher repair man but i know about mechanical and electrical equipment. sounds to me like a motor has burnt or burning out probably with one of the pumps. if its during wash then its the wash pump if during drain then the drain pump (im assuming these are two separate pumps)
Dec 20, 2012 | Hoover HED661280 Dishwasher
Macbook wont turn on, burning smell
Hi, I have the same problem. Now is in the Apple Store for revision. I'll let you know when they give me an answer.
Jun 02, 2012 | Apple MacBook Air
Engine light blinks on and off smell of something burning underneath hood
try to find smell is coming from . dont see smoke or hear anything humming / clicking or feel any wires getting hot . but i would unhook battery when not workin on .its not blowing any fuses or relays . feel you postive cable to see if it getting hot.
Dec 26, 2010 | 2003 Saturn L-Series
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Acrid electric smelling smoke pouring out of machine when pumping down wash water. motor feels hot to touch.
If you are not overloading the machine, and the front of the motor is pretty hot, then it is going bad. If it smells like rubber, it is the belt.
Jan 14, 2010 | Amana DLW330RA Top Load Washer
The washer will go into final spin, it seems to be
Well there could be few things causing the smell and the tub not turning. Its possible something is restricting the tub from turning and the motor is over heating. It is also possible that the transmission has a broken gear and you are smelling something from it getting hot inside. Or you could have a bad belt or coupling. Also the water pump could be stopped up. Its hard to tell because there are so many different types of washers and Im not sure which one you have I assume it is a whirlpool late model.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Emerson Keyed .5hp Fullrate 115/230v Logo
183 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
