Question about GE Dishwashers
Water not draining, but not overflowing after wash cycle. GE dishwasher Model GSD500L-01AW
    Top Expert:
  • GE Master
  • 12,650 Answers
Check and clean floor drain of unit
Posted on Oct 07, 2009
GSD4020Z07BB won't drain. replaced pump and piston nut
When you replaced the pump I am assuming you replaced the whole assembly that pumps water for the wash and drain. See item 310 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dishwasher-Parts/Model-GSD4020Z07BB/0432/0130000/G0040034/00003?blt=15&prst=&shdMod=
If the dishwasher goes through the wash cycle then it was unlikely the thing that was faulty. The pump is shared by both the wash and drain cycle. It is likely the impeller (item 429) is not getting the pulse to change direction so that it draws water from the drain sump to the drain hose rather then to the wash arms as it does in wash cycle. The solenoid connection might be faulty or the controller output is not there.
Apr 21, 2014 | GE 24 in. GSD4020Z Built-in Dishwasher
Drain stays open after start so water doesn't stay in dishwasher for wash cycle. Model GLDT696TSS
Looks like a pressure switch problem. Refer part 26 in this diagram. The drain pump operates instead of the wash pump.
Sep 22, 2011 | GE GLDT696TSS Builtin Dishwasher
The dishweasher will not drain.
Most likely the filter plate and sump is clogged.
Have you tried cleaning it up. If you cannot hear the pump running during the drain cycle, then it is likely the pump is blocked or the motor is faulty. I am assuming the dishwasher completes the wash cycle - i.e., it takes in water and the arms move, the water gets heated, etc.
please provide full model no. of the dishwasher
Aug 11, 2010 | GE Dishwashers
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher does not completely drain. It leaves about 3 inches of standing water. What could be causing this?
Without knowing the model of this GE ? dishwasher, it is very hard to be specific. Most DWs have a float/switch that sense when the dishwasher is filled and empty of water. They can fail.
If you can run a cycle without the dishwasher over flowing but it simply does not fully drain, I would pull the lower spray arm and the filter beneath that arm. Look closely for debris that could be blocking the pump. SOme dishwashers simply have a timer that controls each phase of the wash, including the drain cycle. If something is blocking the drain pump, an obstruction could cause this problem.
Good Luck, Please report back with what you find.
Apr 05, 2009 | GE Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Jan 08, 2008 | Dishwashers
Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Jan 25, 2007 | GE 24 in. GSD1000G Built-in Dishwasher
Dishwashers Logo
201 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
