Question about Acard Technology (ARS-2030LD) DVD±RW Burner
TARGET OVERFLOW ? / ARS-2030 LD COPY SMART PLUS
I AM TRYING TO DUPLICATE A DVD BUT AFTER `PREPARATION` THE
COPIER KEEPS STATING THE WORD `TARGET OVERFLOW` AND ALTHOUGH THE DVD FILM IS ONLY 98 MINS LONG WHY DOES THIS HAPPEN AND CAN IT BE SOLVED ?
PLEASE X PLAIN AS SIMPLE AS POSSIBLE AS ITS DRIVING ME MAD, AND I THINK THERE IS A SIMPLE EXPLANATION ?
MY BLANK DVD IS 4.7 G.B BUT DO I NEED A LARGER DISC CAPACITY
TO COPY THE DVD. MANY THANKS, RAY.
  • 3 more comments
  • FAT BOY FAT Dec 25, 2007
    thaNKS FOR YOUR HELP. I DID FORGET TO TELL YOU THAT
    MY ACARD 2030LD COPIER IS NOT CONNECTED TO A PC AND THAT WHEN `TARGET OVERFLOW` APPEARS AFTER `PREPARATION` OF THE DISC. WOULD A DUAL LAYER BLANK DISC DO THE TRICK . RAY.
  • Spidermaggie Feb 18, 2008
    Have the same problem as Fat Boy. Reads Target Overflow.
  • Anonymous Mar 14, 2008
    i'm having the same problem.
  • Anonymous Jul 22, 2008
    when i try to duplicate dvd using acard i get the message target overflow, whats the problem?
  • xbox360world Jan 16, 2009
    I keep getting target overflow i am using a pioneer 116d dual layer burn with dual layer discs
Your source dvd is most probably a 8.5Gb disc. You will need a blank 8.5Gb disc to copy to.Check out the size of the file on the source disc or the capacity of the source disc. If it is greater than 4.7 Gb.If you are using a 4.7gb to copy to,it will bring up an Overflow message.
Posted on Aug 12, 2008
  • 98 Answers
There is no such dvd bigger than 4.7gb. Are you using nero, as it will show you how big the info you are trying to place on your disc is. You will know straight away if your info is too big. This is what the 'target overflow' means.
It will depend totally what software you are using.
Posted on Dec 23, 2007
  • David Van Oeveren
    David Van Oeveren Dec 25, 2007
    Sorry mate, this is beyond me. I have never used one.
Driver out of order,change...
Posted on Sep 01, 2008
Ascard ars-2032 ld not coping dvds
Copy protected? Wrong type of DVD +r not -r? DVD recorder faulty?
Nov 17, 2016 | Computers & Internet
Source Drive read disk error
The Cd you are trying to copy may be damaged, take it out clean it and try again, if that doesn't work check that the media you are trying to copy is compatible with the source discs, wouldn't be the first person to try copying a CD onto DVDs or vice versa, an easy mistake i've done this myself
Feb 09, 2013 | Acard Technology (ARS-2030LD) DVD±RW...
Target disc not empty
Target disc ( this is what you've selected to burn TO) is not empty(is not a blank disc). You should try a different blank disk, or else you have your source and destination backwards.
Nov 16, 2012 | Acard Technology (ARS-2030LD) DVD±RW...
I have the 1 to 7 ARS-2032 CD-R/RW with firmware 184t, can this work with IDE DVD?
No, ARS-2032 only work with CD-RW, It's CD copy controller not DVD/CD copy controller.
Sep 09, 2010 | Acard Technology (ARS-2032) CD-RW Burner
IM TRYING TO BURN A MOVIE AND THE BURNER KEEPS SAYING TARGET OVERFLOW. HOW DO I FIX THIS PROBLEM
u need to use a larger recorder dvd the file is to large to fit onto whatever format your using
Aug 24, 2010 | Computers & Internet
When i push copy on my DVD burner it says,Target Overflow,what do that means becouse it wont let me burn nothing its a[ TEAC 1 1 DVD/CD duplicator]
It happens to me also ALL the time with mine. I have a 7 disc duplicator machine I do for weddings and special events. And it's a real pain and costly to have that come up when you need the project done soon. My solution is to change the brand on the master disc. Burn another copy of the master disc on your computer to another brand and then use that brand as the new "master" in the duplicator. (1 sollution)
"Target Overflow" basically means that either sometimes the master disc has too much information on it to burn than the disc you want to copy can hold, or sometimes a CD may be in by mistake instead of DVD. If you have a Dual layer DVD disc you want to make copies of and you only have the basic 4.7GB standard DVD blank disc..it's not enough storage space on the disc to burn so you will see that error also. It should really say "not enough space to burn) lol..but I guess that's asking too much.
Sometimes all is correct with the DVD size and it'll come up for no reason (usually the master disc is still spinning and hasn't stopped but you've already pressed the "Copy" button, it's not "ready" so an error of "target overflow" will come up)
I've had mine for 6 years so I've done alot of testing and trial and error to come to the above conclusions.
I find that these brands work for the best "thorough" burns.
Recommended:
Verbatim
SONY
Ritek
Ridata
May 08, 2010 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
How do i burn dvd's
http://dl.acard.com/manual/english/ars-2030ld.pdf
http://dl.acard.com/manual/english/Duplicate%20Controller%20Functions.pdf
Apr 17, 2010 | Acard Technology (ARS-2030LD) DVD±RW...
Targer drive not ready.
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Hope this helps anyone in need out : )
Jun 20, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
2,306 people viewed this question
Top Acard Technology Computers & Internet Experts
Alun Cox
DROPNDEAL
DROPNDEAL
Robert Graf
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
