Question about Dell Inspiron B130 Notebook
Hardware I've got a Dell Inspiron B130, The dvd/cd drive is not working properly. It's like it does not recognize that drive. Cd's and dvd's won't play. Help...
  • 1 more comment
  • zebraman1978 Jan 02, 2008
    i have the same problem. I checked the device manager and have an exclamation point !. It says the driver is either corrupt or missing. I tried downloading the driver from dell and when i run it, it tells me that the drive cannot be recognized. the guy who owns the notebook bought a new drive after my suggestion that either the drive or the mainboard may be the problem. We installed the new drive and have the same problem. The disc spins but never works. still doesn't show up in My Computer. thoughts?
    Thank in advance
  • jupiterjones Feb 23, 2008
    I have the same problem. The interesting thing is, I had the problem 1 month ago, called Dell, and they sent me a new DVD/CD drive to insert. I did that and it worked fine for a few weeks. Now I'm having the same problem.
  • Freakzilla69 Nov 16, 2008
    doesn't show up anywhere!!!! the cd/dvd drive it'll eject and i can hear it start to spin but nothing
This happened to me and i called a dell support guy and he fixed it!!!
This is what you do...
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
Then delete the upper and lower filters....
*** i found this in another forum, it was not written by me but it worked for me
**** Please note that this is a solution for this SPECIFIC problem, if you are having another problem dont use it!!
Posted on Feb 19, 2009
  • 205 Answers
You DVD/CD and your hard drive are the two things in your computer with moving parts and they are usually what break first. Your problem is either broken hardware or something software related. If the problem is hardware then the solution is to get a replacement DVD/CD. If it's software it can take some work to figure out. The first step is this:
Click on Start->Control Panel and then double click on System. Click on the Hardware tab and then Device Manager. You should see an item labeled DVD/CD-ROM Drives. Is it there? If it is, are there any question marks or exclamation points next to it? If not, double click on it....a window should open. Does it say this device is operating normally or does it tell you something is wrong?
If everything looks OK you most likely have a hardware problem. Let me know what you find and I'll try to help more.
Posted on Dec 23, 2007
Optiarc 7580s dvd does not recognize any disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
My dvd burner reads dvd's but will not burn them it reads and rites cd's I have no idea what the problem is but i could use some assistance my computer is a dell inspiron b130
The Inspiron B130 is an older (5 to 6 years) budget pc with an optical drive that can read and write CDs but can only read DVDs. So your problem is not really a problem but rather a limitation. Click on the following link to read PC Magazine's review dated September 19, 2006 on the B130...,2817,2007089,00.asp
May 11, 2011 | Dell Inspiron B130 Notebook
I have no sound, the cd player does not work on my inspiron B130, help!!
Hi there! Try downloading this latest audio driver from Dell:
Run and install it the reboot your system.
Now, with the cd/dvd not working, go to start and click run... type regedit and delete the upper filter and lower filter from this pathfile:
Restart the machine and cd/dvd should work this time, otherwise, you may need to replace your cd/dvd rom drive.
Hope it helps... ^_^
May 15, 2010 | Dell Inspiron B130 Notebook
My dell inspiron 1300/B130 will not load windows from the hard drive or from windows disks.thru the cd/drive Could there be a problem with the motherboard? I can load win 3.1 from my external A drive but...
Step 1 Check BIOS setting to make sure the CD is recognized by machine and is part of the Boot Order sequence. Preferably, the CD should be first in the boot order.
Step 2 Check CD cable connections to make sure they are tightly fitted into their sockets. Also make sure CD is plugged in and CD is getting power.
Step 3. Swap out cable ribbon. Sometimes these go bad. Hope this helps.
Apr 02, 2010 | Dell (E210882) Motherboard
Won't recognize CD, it makes a lot of noise, like if is running but nothing happens. (Dell inspiron 1420 laptop)
U need to reinstall the driver for you cd/dvd rom drive u can do this by "Start right click computer select properties click hardware tab ,device manager then dvd/cd rom drive uninstall driver then click action tab check for hardware change i should be gone after this step go to the dell web site and download the correct driver for your cd/dvd from the web site here is the link this should fix the problem hope this helps
Oct 11, 2009 | Dell Inspiron 1420 Laptop
Dell inspiron 1525 cd drive not recognizeing
ok what you do is go to control panel and system and then click ur driver and then install the dvd one
Aug 03, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
96 people viewed this question
Alun Cox
