Need Ext. cables for the 4 pin conn. of the Lite-on PA-1181-02
If the person above ever got the specs and made those cables I would be interested in purchasing some.
  • 2 more comments
  • stevens509 Oct 07, 2009
    I need a 10 foot extension of the 4 pin power connection from a lite-on pa-1181-02 power supply and if they work well I will probably need about 100.
    I need extension cables at least 10 feet long for the 4 pin din connector comming off a lite-on PA-1181-02 powersupply its a four pin din with one flat side.. If I can find a good supply may need about 100 or so.
  • Art Ellison
    Art Ellison May 11, 2010
    What is it you need?
  • 537 Answers
Is this an internal CD-ROM drive? I don't know if there are extender cables available. I would just look for the correct type, but longer. I'm pretty sure there are 24" or 36" cables available.
Posted on Oct 07, 2009
My 97 starts fine but check engine code says neutral safety switch?
wow, no DTC stated, so we must guess which one, and IS KEY to the cause..
ah , smog fails for CEL glowing
said but true
and it dont lie, the switch , conn. or wires to it are bad.
the real question is where is it and how to test it.
you can google neutral safety switch all day and learn what it does.
The TJ jeep
has. the 42RLE box.
TRS it has. "transmission range, switch"
here it is.
26131331-sfgrgt5j1genusl55xvezfzt-4-0.jpg seen here
TRANSMISSION RANGE
SENSOR
DESCRIPTION
The Transmission Range Sensor (TRS) is mounted
to the top of the valve body inside the transmission
and can only be serviced by removing the valve body
assembly. The electrical connector extends through
the transmission case (Fig. 249
26131331-sfgrgt5j1genusl55xvezfzt-4-1.jpgREMOVAL
(1) Disconnect the TRS connector.
(2) Remove valve body assembly from vehicle. (OOPS)!
(3) Remove the manual shaft seal (Fig. 250).
(5) Slide TRS off of manual valve shaft.
INSTALLATION
(1) Install the TRS to the manual shaft. Make sure
TRS locating pin rests in manual valve bore slot.
(2) Install the TRS/manual shaft retaining screw
and torque to 5 N·m (45 in. lbs.) torque.
(3) Install the manual shaft seal.
(4) Install valve body to the transmission.
my points! given above. facts.
check fuses first.we check the voltages second at p/n sense pins.check for corrosion on the 3 pins related,even re-seat all connectors and pray it goes away cleaning all 3 with real electrical conn spray.does this help?
btw , you never asked a question?
1: how can I fix this.?
2: who, can? (any ASE shop on earth)
3: what parts do I need? (a TRS)
4: what are the steps. (posted)
so i guessed, 1 and 3 and 4.
Mar 15, 2016 | 1997 Jeep Wrangler
I need to replace the Spring.ext on my Craftsman XLT1000 Tractor. It is part number 917272420 or #61 in the owners manual. I cannot see where the spring attaches to - but it looks like it goes to one
This is on the end of the deck lift cable. fwd side attaches to the top of the carriage bolt (146) with pin (45). The back end is attached to the cable (not listed in manual that i can see) and the Sway Bar Bracket 38/42" deck (4) with pin (149).
Jul 28, 2014 | Craftsman Garden
Why doesn't my radio operate in the "PA" mode?
Some radio's do this (specifically Uniden) for some unknown reason. Ideally you plug a speaker into the PA output and when you switch to PA mode, the CB transceiver part should turn off and only your voice should come out of the PA EXT speaker to make it act like a personal megaphone.
Jul 07, 2014 | Uniden Pro505xl 40 Channel Cb Radio
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
How do you set timing marks on 1999 Toyota Rav 4 ?
must have timing lite. Hook timing lite up to battery place spk lead to #1 cylinder remove cover from data link connector (rectangler box on fender well) lid of box has diagram of pins short pin TE1 to E1 loosen distributer and set timing to spec. Spec should be on emission lable under hood.
Jan 12, 2011 | 1999 Toyota RAV4
2004 2500HD ext cab short box 6.0 L no 12V power
No there is not a inline fues. Have you hooked up the wiring to stud 1? It doesn't come from the factory hooked up.
Nov 25, 2009 | 2005 Chevrolet Silverado
Need adapter for 4 pin power supply and no place for data cable,red one,
This is an example of a Y-splitter cable for a 4-pin Molex connector, (4-pin Molex connector is also referred to as a Peripheral power cable),
http://www.directron.com/cbl-y.html
There is a 4-pin Audio port on the back of the Lite On LH-20A1H burner.
Looking at the back, start at the Left side. It is the third port from the left.
This shows the Audio connection,
http://www.newegg.com/Product/ShowImage.aspx?CurImage=27-106-055-04.jpg&Image=27-106-055-02.jpg%2c27-106-055-03.jpg%2c27-106-055-04.jpg&S7ImageFlag=0&WaterMark=1&Item=N82E16827106055&Depa=1&Description=LITE-ON%20Black%2020X%20DVD%u00b1R%20DVD%20Burner%20W%2f%2012X%20DVD-RAM%20write%20and%20LightScribe
Sep 08, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
ADD TALKBACK TO A UNIDEN 510 WITHOUT A PA JACK
In theory you could locate the AUDIO pin from the back of the mic jack, and add a resistor from there to the center pin of the ext speaker jack in the same manner as you would a PA jack.  But look into more before you do as I have never done it that way and Unidens sometimes have a funky way of wiring their boards.  If I had one laying around I would try it out but I don't.  best of luck!
Jan 22, 2009 | Cobra 150 GTL DX Base CB Radio
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
