Question about Qca Spas Paradise Series Paradise Supreme Xlp Hot Tub
My spas is lock how to unlock spas calderas - Qca Spas Paradise Series Paradise Supreme Xlp Hot Tub
  • 2 more comments
  • carlmilot Oct 08, 2009
    my spas calderas is lock i want to unlock
    yes i try but the set button not flashing
    my spa is lock i want to unlock is spas calderas paradise
    President:
  • 1,015 Answers
  1. To lock/unlock the spa, press the “set” button and then (the word “set” will be flashing) press “temperature up” button once, wait 10 seconds before pressing any other buttons.
  2. To lock/unlock the spa’s temperature, press the “set” button and then (the word “set” will be flashing) press “temperature down” button once, wait 10 seconds before pressing any other buttons.
Posted on Oct 08, 2009
  • muebe Oct 08, 2009
    Did you try these instructions????
  • 10,515 Answers
Read the manual :-
http://www.calderaspas.com/Customer/pdfs/caldera_paradise_manual00.pdf
Let me also provide you, if the manual would not help :-
"The locking features, TEMPERATURE LOCK and SPA LOCK, are enabled fromthe control panel by a specific combination of buttons. Once enabled, alock will remain active until the specific button combination isapplied to disable the lock. Even if power is disconnected from the spaand soon thereafter reapplied (such as a power outage), the lock willremain in place."
This leads me to believe that if the power tothe spa was inturrepted and not reapplied "soon thereafter", the spa'scontrols would re-set to default.
On my '07 Geneva you do this to lock and unlock:
"Toactivate the Temperature Lock, press “SET” button + “TEMP ▲ “ buttonand hold for three seconds until lock symbol is illuminated.
Todeactivate the Temperature Lock, press “SET” button + “TEMP ▲ “ buttonand hold for three seconds until the lock symbol is no longerilluminated."
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied.
  • 10,865 Answers
Hello. You might try turning off the breaker to the spa for ten minutes or so. Here is the info for some but probably not all of these spas.
"The locking features, TEMPERATURE LOCK and SPA LOCK, are enabled from the control panel by a specific combination of buttons. Once enabled, a lock will remain active until the specific button combination is applied to disable the lock. Even if power is disconnected from the spa and soon thereafter reapplied (such as a power outage), the lock will remain in place."
This leads me to believe that if the power to the spa was inturrepted and not reapplied "soon thereafter", the spa's controls would re-set to default.
"To activate the Temperature Lock, press “SET” button + “TEMP ▲ “ button and hold for three seconds until lock symbol is illuminated.
To deactivate the Temperature Lock, press “SET” button + “TEMP ▲ “ button and hold for three seconds until the lock symbol is no longer illuminated."
I hope this helps.
    President:
  • 1,564 Answers
Please describe what you are trying to do? If the unit is not operating or are you getting some error codes?
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
How do I fix my tropics sea spa by unlocking it's control panel?
try holding the " lock" key down for more than 10 seconds
Nov 25, 2015 | Pool & Spa
Caldera olympia highland spa keeps tripping breaker
with power off take heater wires off make sure to mark them so you know which is which if it doesnt blow fuse it is heater element if it still does hook back up then try to disconnect the recirculation pump just keep eliminating things
Mar 02, 2014 | Caldera Spas Highland Series Olympia Model...
My temp lock wont unlock
shut off power and restart the unit..may need reprogramed
Aug 28, 2013 | Hot Spring Spas Tri-x Spa Filter For Vista...
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Nov 05, 2010 | Pool & Spa
Caldera spas hot tub Olympic model blows circuit breaker trying to heat up
Remove all pwoer and then gain access to the heater probe. Read each probe from the center connector treminal to the metal base with an Ohm meter. There should be no reading. If you have low reistance the probe is internally shorted and will need replaced. It is a common failure for a heat probe. If the probe is bad when you do buy a replacement buy the "Coated" element. The extra $15.00 is well worth the investment in the overall lifetime of heating element service.
Replacement elements can be found here
Thanks for using FixYa.
Kelly
Mar 22, 2010 | Pool & Spa
Want to install xp by caldera dr dos
The problem is hard enough for beginners . First :
1.DR DOS is used by ASUS . DR DOS isn't MS-DOS (Microsoft), just 99% compatible with it . You have access with it on whole HDD+cd/dvd but , because drdos will enable only 8MB RAM you can't install winnt.exe from i386 . There are at least 2 solutions :
a. if drdos is enable because u reseted BIOS try to change bios according to a better result (avoiding Caldera) and start a nice windows installation;
b. u may use another desktop/laptop until the first restart (in installation) ; u must try to use a computer with ~motherboard for best results.
Don't forget that DR DOS Caldera is almost every time used on ASUS MBs with all on board and you must have a PS2 keyboard/mouse to use any kind of DOS . I read sometimes that DRDOS is a soft used by Microsoft which it's wrong - there isn't any link between drdos and any windows system , genuine or not .
DRDOS problem might appear because it's a soft put on ASUS MB cd driver and , sometime, might be on a BIOS ROM .When u will boot with the MB cd driver in this kind of problem might occur .
Other way Caldera may appear is when u have a windows cd made careless with NERO and caldera will appear no matter the MB .
Mar 24, 2009 | Microsoft Windows XP Professional SP2
Qca Spas Paradise Series Paradise Supreme Xlp Hot Tub Logo
2,584 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
