Question about Kodak EasyShare V1073 Digital Camera
It quickly turns off when turned on, the lens wont go in when off
It quickly turns off when i turn it on, the lens wont go all the way in when it's off.
    Sergeant:
  • 151 Answers
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Posted on Oct 08, 2009
  • 797 Answers
First I would check the battery, and make sure it is either fully charged, or has new batteries.
If you can get the menus, set all to factory default.
If none works, then it needs repair.
Posted on Oct 07, 2009
3 Suggested Answers
Gwenivie
  • 39 Answers
SOURCE: Cameras lens stuck out and wont turn on
I agreed with Mark Sox. Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
To explain about the lens that stuck out, it's lacking energy required by the lens to go back in since there is improper power connection if battery type was not set to the correct one.
About the SD cards to be used with this camera, those could be:
- MMC / SD card (Up to 2GB Guaranteed)
- SDHC card (Up to 4GB Guaranteed)
Some cards are not compatible according to the memory card
manufacturer and memory card type.
I hope this help you a lot.
Posted on Jan 11, 2008
  • 5 Answers
SOURCE: lens was stuck popped out
HEY I HAVE THE SAME CAMERA AND SAME PROBLEM !!
TO FIX IT : TWIST ON THE LENS WITH UR HANDS AND I WILL GO BACK DOWN
Posted on Jul 18, 2009
My kodak m583 tells me there is lens obstructed,and wont turn on
This video illustrates troubleshooting steps for a lens obstructed error:
Dec 13, 2012 | Kodak Easyshare M583 Digital 14mp Camera
My nikon s550 wont extend
What finally worked for me was a mix of the ideas listed here. I placed a vacuum hose against the lens and turned on the vacuum, then turned on the camera and tried to gently pull them apart. There was just enough suction to pull the lens through the spot it was sticking on and PRESTO! It works again! The focus was nasty at first, but another quick power cycle fixed that up. The lens hasn't locked up again despite many power cycles. I used a proper canister vacuum which happens to have a new bag in it, so plenty of suction.
Jun 01, 2010 | Nikon Coolpix S550 10 Megapixel Digital...
I dropped my camera that i bought in feb went to
Sorry, no can help. Take it quickly to the repair shop before you loose any parts.
Oct 23, 2009 | Kodak EasyShare Z710 Digital Camera
My lens won't close
My camera does the same thing. It is getting progressively worse. To get it to work, I have to open the battery door and push the battery a little and finally the camera will turn on and lens will close. Something is wrong with the connection at the terminals and I don't think its something that the owner can easily fix, but at least you can jump start the camera working again. Its just a pain to have to fiddle with it sometimes and it scares me that it might not start again one of these days. If its under warranty get it turned back it quickly.
Sep 12, 2009 | Kodak EasyShare M863 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Can't get my lense off!
You can use any mm lens you want as long as it was made to fit the K1000.
Is the lens a Pentax lens ?
Push the lens release button down and turn lens Clock-wise then while holding release button down quickly turn lens counter clock-wise, it should come right off.
If it did not then it must be disassembled to remove the lens.
Oct 31, 2008 | Pentax K1000 35mm SLR Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Problem in Olympus FE-170 Digital Camera
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 13, 2007 | Olympus FE-170 Digital Camera
Kodak EasyShare V1073 Digital Camera Logo
122 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
