Question about Toshiba Satellite A105 Notebook
Okay ihad to take the computer apart to put the
Okay i had to take the computer apart to put the touch pad board in it and a keyboard in it now the on and off button doesn't work i can't get it to come on unless i unplug the the little thing on the inside of it what have i done to it dstringfield@hotmail.com
    President:
  • 2,600 Answers
There is a small cable that leads from the power strip to the motherboard. If that came unplugged, the motherboard will not get the signal from the power button. Pull the keyboard and power strip back off and check for connection at the power strip and motherboard.
Posted on Oct 07, 2009
Lenovo Touch pad Stopped working
If you're positive you didn't unplug or rip anything while installing new USB ports, trying checking/updating or rolling back the drivers for the touch pad. Installing new USB ports could have mis-configured something and disabled or modified your drivers for the touch pad.
Mar 12, 2014 | Lenovo IdeaPad Y550 Notebook
Laptop touchpad not working
Directly above the touch pad is a button (sometimes has a light around it red off, blue on). This button turns the touch pad off and on. Once you press the button, give the laptop a second or two to recognize the device and then try it. If this does not work look under device manager, to see if there is anything next to your mouse devices. If there is an explation point or anything you probably need to reload the drivers. If there is a red X, this will normally indicate the touch pad has been disconnected physically. If you are somewhat hardware savy, remove the keyboard and check/reconnect the touch pad.
Hope this helps.
p.s. no I did not give instructions on how to take apart the computer or remove the keyboard. If you do not know how to do this, I would not recomend that you do.
Apr 12, 2012 | HEWLETT-PACKARD 620 XT964UT Notebook PC
The b key strikes to hard, so there is any touch resopnce on the middle B key, what can i do to fix if?
You will have to clean the keyboard touch pads. its a pain full job because one has to remove at least 50 screws before one gets access to the key pads. Remove the back cover and make a note of what screws goes ware.Then remove the screws that hold a long circuit board over the keyboard ( lots of small screws ) . Invert this board and clean the black carbon tracks as well as the rubber key pads with solutions like WD40. Install it back in the reverse order making sure you put all the right screws in the right place. Should work fine after that until dust again gets in between.
Sep 26, 2011 | Yamaha Mm6 Synthesizer Keyboard...
Touch pad problems
Most of the toshiba laptops can disable touch pad with FN + F9.
In F9 key u can find touch pad picture.
May 27, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Keyboard does'nt work
Step1:Check whether the Keyboard and Touch pad BUS Cable connected to the Motherboard.
Step2:Clean and Re fix the BUS Cable.
Step3:If Still it is not working Circuit Board need to be replaced.
Pharthiphan
Nov 06, 2009 | Compaq Presario 700 470024-192 Notebook
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
Jun 13, 2009 | Acer Aspire 5610-4648 Notebook
Think pad T40
It's possible that this is a hardware problem, but it sounds more like a loose connection to me. Start by removing the keyboard and checking all visible connections. You should be able to see the touch pad, keyboard, and screen connections with the keyboard off, and, yes, I realize that you cannot check the keyboard connection with the keyboard off, but you can when putting it back on. For some reason I keep getting people that love to point out the obvious lately, so I'll throw that in there right off the bat. Also check the hard drive to see if it's seated properly. If the problem persists, you may need to take the cases apart and check all connections on the board.
Aug 22, 2008 | IBM ThinkPad T40 2373 Notebook
Number pad on iMac keyboard inactive
Press "clear" on the numbers pad, then the numbers will type.
Jul 28, 2008 | Apple Power Mac G5 Desktop
Keyboard and touch pad locked
You need the password to unlock it.  If yo don't have it you are out of luck. Password is stored on a separate chip and needs special tools and knowledge how to replace it.
If your laptop's memory can be upgraded there is usually a small panel you remove under the laptop. Then you need to tell some one at the computer store where you buy memory chips the make and model so they can give you the right chip.
Oct 31, 2007 | Acer Aspire 5050-3242 Notebook
Unresponsive key board
Most notebooks have touch sensitive pads or switches underneath the keyboard, unlike a normal keyboard which is less complicated. You can try and remove keyboard and check underneath, but it may be that the circuitry that works certain banks of keys is damaged or shorting. Not a job for faint hearted i would recommend a qualified repairer.
Dec 22, 2006 | Compaq Presario R3240US Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
