Question about Avanti DG241BS Stainless Steel Gas Kitchen Range
Thermo coupler problem
I have owned this oven for about 3 years and it has been nothing but grief.
The stove top works, but there is some sort of defect with the thermo coupler that controls internal oven temperature - there are complaints about it on other websites. When new, the oven never maintained the correct temperature -- it ran very hot -- about 500 degrees no matter how I adjusted the thermostat. When I finally called a repair man, I was told the oven needed a new thermo-coupler. The part if hard to find, so I ordered it from the AVANTI head quarters in Florida. It took 3 MONTHS for the part to arrive from China. The AVANTI service department is unpleasant and unhelpful.
The replacement piece was installed and the oven would not ignite.
At this point I gave up and decided to buy a new 24 inch oven.
Surprise!!!! The AVANTI oven is not really 24 inches wide -- it is 23.5 inches wide. Since my kitchen counters and cabinets were custom built around the oven, I don’t have enough width to replace it with a real 24 inch oven - it won’t fit. If you are looking for a 24 inch oven, buy a Summit oven -- I own one of their fridges and it works great.
5 Suggested Answers
solveditnow
  • 39 Answers
SOURCE: Avanti DG241BS - oven will not stay on
There has to be a protection system in the burner assembly to cut the supply of gas to the burner if it does not light. For the case of an oven the supply must be cut off immediately if the burner and its pilot go out. For that gas control system to work the burner control must "recognize" with a sensor when the burner is lit and when it is not. Pushing the knob "in" momentarily on this model bypasses the protection system momentarily to allow a burner to be ignited in the first place. If releasing the knob extinguishes the flame the control system is not "seeing" the flame. I tried to find some detail info on you particular ignition system but to no avail so all I can offer is a general approach to these kinds of problems . You need to find and clean or replace the sensor used to detect a flame. It could be an optical one (doubt that) or a temperature flame sensor, a thermocouple sensor, or some other kind I haven't thought of. Fixing this problem involves first determining what kind of sensor it uses. A copy of a service manual for this model can help you determine that. Try to clean the flame detector, and if that doesn't work you have to replace it or the gas control assembly it is a part of. If you have a spark ignition and its not sparking when it should first clean it --carefully--. Spilled food can short them out. Unplug the range before doing this. The owners manual shows it to be under the top burners which can be removed for cleaning this.
Posted on Jan 03, 2009
vanni7
  • 163 Answers
SOURCE: HI, i am in need
hi!!!! call 1-800-323-5029 or 1-877-359-6409 for service tech questions and parts.Good luck..128bc2f.jpg
Posted on Jan 27, 2009
SOURCE: Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Posted on May 05, 2009
SOURCE: Igniter on Avanti G20AW-1 stove fires by itself every 8 seconds
broiler igniter fires but lower burner igniter wont fire
Posted on May 17, 2010
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
I NEED A SERVICE MANUAL FOR MY VERMONT CASTING RADIANT GAS STOVE MODEL RMV40
This should get you to the right manual for the rnv40 Vermont Casting located in conneticut 1-855-415-0071 8am to8pm EST
Nov 17, 2012 | Grilling
My stove does not get hot enough
your oven/stove thermo-couple has gone bad and senses too much heat too soon before its actually hot and shuts off the gas supply,it is located inside the oven cavity in a clip on the top of the oven cavity and is normally replaced with the oven control dial as a calibrated unit
Jun 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
The pilot light on my caloric gas oven lights, but the oven burner doesn't light. The oven is old, but only used for 2 months before being put in storage for 13 years. The stove top burners work fine,...
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Nov 26, 2009 | Ovens
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
My maytag over the oven microwave just died;
most likely the power supply in the microwave is gone. the microwave die probably it is over the oven. heat from the stove cause the microwave to heat up and cold off more than it is on the counter.
counter microwave has fan and air slot in the rear. it keep the motor and microwave cool, and there nothing else to keep it hot. but the over the oven, the only ventalation is from the top. and with the added heat from the stove top and oven.
Apr 27, 2009 | Maytag MMV4205 Microwave Oven
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Oven wont regulate temp
is your temp control operated by a knob or push button?
Nov 22, 2007 | Kitchen Ranges
Avanti DG241BS Stainless Steel Gas Kitchen Range Logo
106 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
