Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
2003 Dodge Heavy Duty Ram will not shift into 3rd gear
2003 Dodge Heavy Duty Ram Club Cab with diesel engine will not shift into 3rd gear unless rpm's fall below 800. This has 5spd manual transmission and regular diesel engine not high output.
    Problem Solver:
  • 6 Answers
Check your vacuum lines for transmission and do you flush and maintain your transmission?
Posted on Oct 07, 2009
I have a Dodge 3500 Ram with an Automatic 6 speed transmission. I pull a Gooseneck trailer with a GVW of 16k lbs. I have no issues when I am on the road, but when I leave the highway or I'm in heavy...
sounds like you may havea torque converter lockup issue, one way to check is while in slower traffic (15-35mph) gear down your transmission such that you are at a higher rpm (2000-2500) then take your foot all the way off the throttle, if it is in lockup your engine rpm will stay about the same, if not it will go to about idle.
If the tcc doesn't unlock while shifting it will shift very hard and if it slips it will make your temperature increase
Sep 22, 2013 | 1997 Dodge Ram 3500 Club Cab
92 dodge ram 150 not shifting
Two things happen on the Dodge's. 1. the rear O2 sensor shorts out and meses things up. 2. the Inner seal on the Direct drum (3rd) shrinks and causes a delayed up shift.
Aug 05, 2008 | 1996 Dodge Ram 1500 Club Cab
Dodge 2500 diesel 1999 engine light code PO753 want to know how to conferm problem
The code is for a shift solenoid apparently
Google it
Unless you work on your own veh- then you
need a trans or repair shop
Jan 21, 2013 | 1997 Dodge Ram 1500 Club Cab
1996 dodge ram 1500 4x4 low voltige to transmission
If you only have 5 volts you may have a bad battery or alternator. Or maybe a B+ (battery positive) wire short to ground. Check voltage engine running at the battery then alternator +. If your voltage is that low your TCM won't work.
Jul 28, 2012 | 1996 Dodge Ram 1500 Club Cab
96 Ram 1500, 5.9 litre. code PO138 sensor circuit
it will be the o2 sensor after the cat.. check the connections. the first bank should be the right side of the engine while sitting in the car. look at that side of the exhaust.
If you need further help, reach me via phone at https://www.6ya.com/expert/ayron_57e1b351b7242eef
Jul 20, 2010 | 1996 Dodge Ram 1500 Club Cab
My 97 dodge ram 5.9L does not shift into od it
If this is a 5.9 diesel Clean all the battery terminals, especially clean all the wires on the drivers side battery. Give me feedback if this helps
Feb 16, 2010 | 1997 Dodge Ram 1500 Club Cab
Hard shift from 1st to 2nd, then 2nd to 3rd.
Dont think they changed it yet but the older chrysler units had a rod that went from the throttle linkage to the transmission (maybe a cable now)...If you lengthen the rod it will increase shift pressure and give you an earlier shift.
Jul 17, 2009 | 2002 Dodge Dakota Club Cab
1996 2500 diesel auto transmisssion, auto shifting while on road
sounds like trans has gone bad, last service of filter and fluid? clogged screen or low/burnt fluid would effest but if clunking sounds like trans is shot
Jul 06, 2009 | 1996 Dodge Ram 2500 Club Cab
1999 dodge ram delayed and erratic shifting
ummm i would say you need to adjust your trans shift cable, check your fluid level, and the problem i had with my dodge was similar to yours... it was my 3rd-4th actuator spring, it had broke and couldnt hold the pressure to keep it in gear
Oct 07, 2008 | 1999 Dodge Ram
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
354 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
