I have a Toshiba 37HL67S LCD and it has audio but no picture. When you turn it on the screen lights up and if you hit the input button it must go through the inputs because I can get the audio back on the input thats hooked up. I can also see the screen change somewhat when doing this but there is no picture on any input I use.The power light is fine. Could it be the main tuner board ?.
  • tpaaaa Oct 07, 2009
    If that does not work, checking the connections. Could it be the big main board where all of the component and f-81 is for a regular cable connection.
  • 61 Answers
It is possible that there is a loose connection of the whole imput bar to the display. the connections should go right back together if they are loose
Posted on Oct 07, 2009
Testimonial: "Thats a very good Idea. I will check all of the connections."
No picture
Look with the set on in a very, very dark room and use a flashlight to light the screen.
If you see a very faint image of the picture the back light in the set is not on or bad---most LCD sets use a back light to provide the source for brightness on the screen.
Dec 12, 2012 | Toshiba 23HLV87 23 in. LCD Television
I have a Toshiba 47hl167 and when I plug it in and hit the power button the green light comes on but no picture?
The real issue is do you have sound or not?
You can unplug the set and or a box both if connected for several minutes and then power back to see if when they reboot set works or not.
Dec 10, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
2008 46" Toshiba Regza, has bad picture when cold
It would help to see a pic or video. The fact that hitting the top side clears up the picture leads me to believe that you may have a bad LCD panel tab. If this is the case, the only true fix is to replace the screen, BIG $$$
Nov 25, 2012 | Toshiba 46XV540U 46 in. LCD HDTV
My toshiba 32av500u has no picture completely blak only power little lit in front . turns on green no kind of sound
I have the same problem with the black screen and no sound. Also the green light turns on and off while hitting the power button. Although if i turn it on then off multiple times it eventually turns on and works perfect... Could you do the same thing before it finally quit all together or did yours just happen over night?
-Kenny
Aug 04, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
No picture on a Toshiba 46RV530U
Turn the tv on and shine a flashlight on the screen. Its hard to see a pic but most likely, its there. For some reason, your lamps in the panel are not turning on. Inverters are my first guess.
Dec 02, 2009 | Toshiba REGZA 46RV530U LCD TV
No Picture, good audio
The backlight in the panel is faulty or one of the surrounding assy boards are faulty.
Seek out an engineer as it not an easy fix and will cost you.
Thanks
Oct 08, 2009 | Televison & Video
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
I have sound but no picture-
evidently your television has P-I-P or picture in picture and you have it turned on and only have one source as an input. You just need to hit the P-I-P button and keep hitting it until your picture is back to the main screen and not the liitle one
Jun 08, 2009 | Samsung LN46B650 46/49.5 in. LCD HDTV
My remote input button is not functioning
take a digital camera, or a camera phone, and get it ready to take a picture, point your remote at the screen, so you can see it in the camers, hit the input button, you will see the infa red lights flash on the remote through the screen, if you see it , then your main board in the tv isnt reading it, if you dont see it flash, there is a problem with that button on the remote, there should be an input button on the tv
Jan 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No Signal
You will have changed the video/audio input, on your tv, it should be an input button on remote. The signal will either be on AV1, AV2, AV3 Component or HDMI.
Jan 24, 2007 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
