Question about Dell Inspiron 1501 Notebook
Dell 1420. screen went blue with an error message saying windows was shut down to prevent damage. If have not seen this error before, shut down and restart. when I press power, the only thing that happens is the caps lock light flashes for about 30 secounds, then shuts off.
    Problem Solver:
  • 8 Answers
It is commonly known as the blue screen of death but all you have to do is press the power button and then turn it back on. It will do a disk check and you may resume your normal activities.
---Tecnogeek
Posted on Oct 07, 2009
    President:
  • 2,600 Answers
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Dell latitude e5510 laptop got blue screen saying that a problem has been detected and windows has been shut down to prevent damage to your computer but it wont do anything ele's help any one
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
Aug 29, 2012 | Dell Latitude E5510 Laptop Computer (Intel...
Blue screen
Yes normally if you don't shut down your system properly you get this message, Solution : Log on to save mode and backdate your computer to the day before you got this message. If it doesn't work, you are gonna need to reinstall your O.S.
Feb 07, 2012 | Dell Inspiron 710m Notebook
Unmountable boot volume + how to fix. Have reboot CD's Errors messages 0x000000ED, 0x8137DE8, 0xC0000006, 0x00000000, 0x00000000 can't get past this screen. keep circling around F8 and the Dell start-up...
Turn off your pc and take the side panel off and remove the cmos battery leave for three minutes
and then replace this will reconfigure your
motherboard and hopefully solve your problem.
Feb 15, 2010 | Dell Dimension 2400 PC Desktop
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Apr 13, 2009 | Dell Inspiron 1501 Notebook
Inspiron 1420 is not booting to windows
Re-boot, Keep tapping F8 until you get to a black screen, last known good is there, choose this, leave it to run,
or try again re-boot, choosing safe mode this time, if/when it boots, then a system restore in safe mode, go back in time.
If still no good, Your O/S disc is now needed,
boot with disc, go for a repair of the install,
Let it run it's course,
re-boot.
Regards.
Apr 10, 2009 | Dell Inspiron Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1501 Notebook Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
