Question about Sony Ericsson TM506 Cell Phone
I have the same thing too :[
At first i thought it was just broken and stuff...But I THINK its probably how its made like if you dont use it for a while it shuts down ... its getting annoying for me kinda.. >.>
Not change code phopne protection
Posted on Oct 07, 2009
I dont know how to rewire the back of my dean evo xm? i tried to fix the faulty input so i thought the wires were faulty so i tried to rewire it and i dont know where everything goes now. theres red yellow...
It is rare that wires would be faulty. Soldering can be, but not the wires usually.<br /> <br /> Common problems are broken jacks or pots that are broken or shorting to the paint in the cavity.<br /> <br /> If you have things unwired now, the best thing is to find an appropriate circuit here and wire it like that:<br /> <br /> <a href="http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/">http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/</a>
Aug 28, 2010 | Dean Evo Xm Electric Guitar
My Van Is not cranking We thought it was the battery but found out that the battery is good. the horn and radio and stuff works but it will not evev try to crank
Are you getting a clicking noise at all? If not, I'd try the starter soleniod. (this is usually the problem - you can take the starter to an advanced auto and they can check it for you to be sure).
Otherwise it's the ignition (where you put your keys in). Sometimes these stop sending the 'start' signal.
Jul 09, 2010 | 2000 Chevrolet Venture
Physical memory dump.
Physical memory dumps usually involve something using entirely too much RAM when they shouldn't be. The dump takes place to free up memory so that the system could keep running. A few things can cause this, few of them good.
If it's happened twice in a day, it probably means that some piece of hardware it about to go (or already has). Safe bet would be that a memory stick (or part of one) has gone bad. Since the computer expects to be able to use that, it's discovery that it doesn't have all the memory that it thought it did traumatizes the poor thing.
Think of how you'd feel if you discovered that your basement disappeared, right after you bought a bunch of stuff that needed to be stored in there. Your reaction might be to react by just throwing stuff away that you thought was no good and just taking up space. The downside would be that you might accidentally throw away something you need.
The good news is that a RAM dump is not permanently removing information; it's just removing it for the session until necessary. Still, dumps often require restarts because something necessary disappeared. It's not really a great analogy, but I think it helps explain the idea.
You might want to do a check on the RAM or the HDD to see what the problem is. There is also a possibility that it's from a program that isn't bright enough to only use the amount of RAM that's there.
Jun 29, 2010 | Microsoft Windows Vista Home Basic Edition...
Thought I got bad gas so I added a can of dry gas and New Gas High octane Now the check engine light is on
first off, you should never put high octane into a car unless racing is what its built for, that stuff can tear up an engine if you dont have the proper upgraded parts to handle it. Once is ok but dont make a habit of it. Second you need to go to an autozone or advanced auto store ond get your codes read for free. They will tell you what the codes mean and what to do next. Its probably an o2 sensor issue.
May 14, 2010 | 2000 Chrysler Cirrus
Over heating when get at any thing over 70mph
I could probably think of other things if the reverse were the case (overheat at low speed, fine at high), but it may just be time to flush and replace the coolant - I think it's supposed to be done every 5 years/100k mile with Dexcool [orange stuff] or 2-3 years 30k normal/yellow. Also couldn't hurt to check the radiator itself for anything blocking the airflow.
Mar 20, 2010 | 2001 Chevrolet Cavalier
It is jammed and does not want to turn on
I think you have broken it.
1.Dont drop it in water
2.Dont drop it on hardware
3.Dont drop it anywhere
4.Dont do to much at the same time to make it freeze
If you did any of these things you have broken it
Dont panic
Oct 07, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Powervalve on top is broken. yamaha 250yz cross.
Stuff happens on a race bike. The problem is that it can happen so fast, with your mind on other things during a race, you don't even realise somthing happened. Another bike probably kicked up a small rock and aimed it at your carb.
Aug 29, 2009 | 2004 Yamaha YZ 250
Frozen laptop
hmm try to reconnect the ribbon cable to you keyboard and pointer but both is bad. it is probably a broken MOBO or motherboard
no worth fixing. if that data worries you then find a computer that can read that harddrive and use that one instead.
Nov 29, 2008 | Computers & Internet
NO Files
update player at rca
Feb 10, 2008 | RCA H100 MP3 Player
Ice Maker Problem
The "ice maker module" is pretty vague. THere's lots of things that work together to make ice. Could be a bad motor, a bad solenoid (electric valve that lets the water in), a broken gear, a loose wire, or just frozen up. If you havent pinpointed the problem, you are probably wasting money buying a new "ice maker module". I'd advise looking for obvious problems (frozen/jammed, no water input, broken looking stuff) and if you dont see anything, call a repairman.
Feb 26, 2007 | KitchenAid KSRS25IL Side by Side...
Sony Ericsson TM506 Cell Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
