Question about RCA D52W19 52" Rear Projection Television
My RCA D52W19 52 in. tv wont turn on
The tv usually the tv works fine. A couple weeks ago I had to unplug it and when I plugged it back in it wouldn't turn on. Eventually it turned back on. Now my power went out and it won't turn on. Nothing not even the green light will come on. Can anyone help me?
snakehead
  • 1074 Answers
SOURCE: rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Posted on Mar 30, 2007
techman
  • 3130 Answers
SOURCE: RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Posted on Oct 16, 2007
Slinteriors
  • 8617 Answers
SOURCE: model D52W19BYX2 RCA
Horizontal output and the low voltage regulators should always be checked first in a set that wont power up. If you need a manual go to http://www.servicemanuals.net/. Be sure to check back if you need some help.
Posted on Jan 05, 2008
MARR
  • 49 Answers
SOURCE: My RCA F32650 won't turn on and green power light just blinks.
yeah the blinks will tell u the culprit..basically cold solder,or bad vertical ic.but u need prof tech to help u fix that..hope this help..yhanks
Posted on Feb 05, 2008
  • 61 Answers
SOURCE: TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Posted on Mar 05, 2008
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
42hp66 plasma tv turns off and red light goes out
Most likely the "Y sustain" board is about to give out.
Oct 09, 2009 | Televison & Video
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
Rca f27450 TV
It sound like your set have dryjoints
Oct 11, 2007 | RCA 32F531T 32" TV
Need help fixing
I had the same problem a couple years ago with mine. After letting it set for several months, I tried to plug it in again after moving into another house. All of a sudden, it started working again. That was 1 year ago, but just last week...it did it again. I noticed that it does this if it is left on for an extended amount of time (my wife goes to bed at night and leaves it on). I cannot find anything on how to fix it, and no warranty assistance from RCA. I'm purchasing a Sony today, but will hold onto the RCA in case it decides to work again.
Sep 29, 2006 | RCA RT2380 System
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
TV wont come on
Most likely cause would be a blown fuse on the power supply if you are getting no lights on the front, no response from the buttons, and no warmth from the back of the set. First check that not only is the power socket in the wall working, but also that the plug on the TV power cord is not faulty or distorted so it doesn't make the circuit when plugged into the wall, also if it has a fused plug, check that. Then if you feel up to taking the cover off, make sure the set is unplugged and leave it for a few minutes first. take off the back cover (usually a few screws around the base of the set, but it should be obvious) follow where the power cord enters the box, and about the first thing it should connect to is likely to have a fuse. Probably a couple of metal spring clips with a glass tube type fuse sitting in them. The fuse should have a rating stamped on it and you should be able to get a replacement at most hardware stores, but make sure you get the same type as well as rating. If a replacement fuse doesn't cure the problem then the next thing to suspect would be the transformer and rectifier circuit - the fuse should have protected these, but sometimes it doesn't work that way. If you need help checking these then please ask again, but I suspect the fuse is your problem. Hope this helps you out, please ask again if you need more info :)
Mar 24, 2006 | RCA F32450 32" TV
RCA D52W19 52" Rear Projection Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
