Question about Hotpoint WMA58 Front Load Washer
Hotpoint WMA58 Washer won't do proper final spin
Hi, when the washer reaches the final spin, it only goes round at a slow pace. The drum does turn, and there are no additional noises, but still it doesn't spin at the quick speed. Any ideas, as it's a bad time to break down.
Thanks
  • 139 Answers
I ve come across this problem many a time... my job is recondtioning these models of machines for the last 3 years..
This problem has three solutions..
the first one is the control board,, very unlikey but has been known,
secondly the wiring loom unlikey but has happend.
Thridly the motor itself ....This is the most common remedy to this problem.
Posted on Dec 25, 2007
Hotpoint wma58 stopped spinning
unplug it for a hour plug back in see if it resets it self
Apr 05, 2014 | Hotpoint WMA58 Front Load Washer
When on spin,the drum is rattling and making a lot of noise
More than likely the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough, or is rumbling or grating, then the bearings have failed.
Dec 03, 2010 | Hotpoint WMA58 Front Load Washer
Hotpoint WMA58 working but will not spin - drum rotates but will not speed up.
It sounds like your belt is loose and needs to be replaced..
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 12, 2010 | Hotpoint WMA58 Front Load Washer
When on final spin, water leaks from detergent draw
You probably need to clean the filter.
Remove lower rear cover of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Hotpoint WMA58 Front Load Washer
It seems that the drum is spinning off its axis
When a front load washer does not spin properly, the problem can be caused by failed axle that connects the pulley to the wash drum, or failed shock or (possibly) broken suspension springs.
Remove washer top, inspect the two or four springs holding the washer drum up. The whole drum should be able to "bounce" a little, when you press down on it.
Remove the lower front panel and with a flashlight, inspect the two shock absorbers. Both should attach up to the wash drum, but it is common for them to break, especially if the front load washer has been moved from one house to another without re-installing the lower brackets and the long bolts that secure the drum during the move.
If the springs and shocks are not damaged, with the top removed look down into the rear area. You will see a large pulley with a belt on it. If you see brown/black grease marks all over or obvious problem when you try to turn the pulley, you have found the major problem.
Please get back to me with what you find. OK?
Jan 03, 2010 | Hotpoint WMA58 Front Load Washer
My 13 year old wma58 makes a lot of noise on spin rinse
To be certain if it is the main bearings, remove the lower rear panel of washer, remove belt, and spin drum from the front.
If it feels rough or is rumbling, then the bearings have failed..
If no noise from drum then it could be noisy motor bearings.
At that age, it certainly would not be cost effective either way.
Hope this helps.
Dec 16, 2009 | Hotpoint WMA58 Front Load Washer
Hi i am having trouble with our wma58, the last 2 washes it has sounded noisy on start up but then washed fine yesterday i put the machine on it seemed to get half way through a cycle then stop all the...
Try the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the filter inside the hose.
Remove the black hose onto the pump, and check for blockage or obstruction here and in the pump.
Hopefully, this will solve your problem.
Good luck.
Dec 13, 2009 | Hotpoint WMA58 Front Load Washer
My machine is making a noise as is it is spinning noise but drum will not spin around. any suggestions
Check to see if you can turn drum by hand, if you can, then prob could be belt, or motor not turning under load, check brushes in motor.
thanks.
Aug 12, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
315 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
