Question about Dell Inspiron 6400 Notebook
How to turn ethernet controller back on ?
How to turn ethernet controller back on , doesnt show up on device manager. computer is a dell 9100 uses xp pro and when you hook up 10/100 pc card it works fine
  • racin_rowdy Oct 07, 2009
    went and hit F2 and did not see ethernet controller but did see NIC at boot up that the same ?
    Problem Solver:
  • 8 Answers
Go into the bios (F2 on powerup) and under Ethernet Adapter, Make sure it says enebled.
Posted on Oct 07, 2009
Motherboard P4i65GV ASROCK. Installed WIN XP service pack 2 , ethernet controller is not installed shows exclamation mark in device manager.Unable to connect to net.
you must ethernet controller driver first
goto device manager, right click at exclamation mark, then chose update driver, follow instuction step by step, if it ask for cd driver insert motherboard cd driver, if you did not have cd driver download ethernet controller here
http://www.asrock.com/MB/download.asp?Model=P4i65GV&o=XP
wait until process finish and exclamation mark at device manager disappear, and try to connect your computer to internet
i hope this helpful
thank you for using fixya
Feb 02, 2011 | Asrock P4i65GV Motherboard
MY DELL NETWORK adapter doesnt work anymore on my dell laptop i cant connect to the internet, im using my brothers laptop to ask this question!
Reinstall the driver for it. You should be able to get it from dell. If it still doesn't work there may be a hardware problem.
Feb 02, 2010 | Dell Inspiron 1525 Laptop
Dell Dimemsion 9100 cannot connect to internet. Windows cannot repair the problem. Tried Windows and Dell drivers for network adapter with same results. Yellow caution sign on network icon.
Hi there
I can understand your issue.
When you same yellow caution i believe the network driver is not installed properly. To resolve this issue please go to device manager.
Locate for the network adapter and click on + sign to explore it.
Below that you can see your network device name, right click on and click uninstall.
Then reboot the computer and that will try to install the network driver ( It works in XP & VISTA). Cause XP & VISTA has the ability to load the default driver.
Then try to reinstall it and that should work.. If still the same issue kindly revert.......
Jan 14, 2010 | Dell Ethernet Card Network Adapter
Just reinstalled xp on a dell dimension desktop 8250 and the ethernet NIC Card just does not show up in the network settings. Everytime I look up the card in Device Manager it has a question mark. I did...
if u have another way to contact dells website with eather a flash usb or a cd get the drivers from dell for you nic then go start/control/system/device manager and update your drivers for that nic
Dec 05, 2009 | Dell Ethernet Card Network Adapter
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
Ethernet Controller is missing
You are unable to use the Ethernet, VGA etc. because you have not installed the drivers for the same.
You might have received a Drivers CD(it will read "Drivers and Utilities") which will be in blue color, when you got the computer from Dell.
In case if you haven't received it you can contact Dell on 1-800-624-9897 and request for a Driver CD. I guess this Dimension model is @ End of Life (I mean no more produced by dell) you might have to download the drivers from Dell's support site (www.support.dell.com) you will have to get it downloaded on a different computer and copy on a CD or a Flash drive.
Once you got all the drivers. First extract them in a separate folder
Go to Device manager
Right click on the Ethernet controller (where you see a yellow exclamation)
Click update drivers
Show the path where you have the driver files
Sep 20, 2009 | Dell Dimension 3000 PC Desktop
The ethernet controller on my Dell Latitude C540/C640 Notebook has not worked in a while. I am able to get wireless internet access, but no luck when I try to connect to my router via a direct line. I...
If you are using Windows XP, go to Control Panel > Network Connections. Right click on Local Area Connection and then click Enable. (This is only applicable if the ethernet port is disabled).
Also, you may go to Device Manager (Right Click My Computer > Manage > Device Manager) and then check if the ethernet is disabled or has a question or exclamation mark.
If both dont work, your ethernet controller is broken.
Jun 07, 2009 | Dell Latitude C640 Notebook
The network adapter in a dell dimension PC running XP home
Ethernet controllers click here
Check for drivers on that site, however much better that you know the brand of your LAN adapter.
Mar 15, 2009 | Dell Dimension 8250 PC Desktop
Sound issue with toshiba tecra 9100
when ever i open my laopyop it says that no audio devices are installed and i have toshiba-satellite a215-s5837
Oct 23, 2008 | Computers & Internet
Dell Inspiron 6400 Notebook Logo
354 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
