Question about ICOM Informatique IC-A23 VHF NAV/COM Air Band Transceiver 2-Way Radio
While receiving the receiver cuts out momentarily approximately every 10 seconds
    Problem Solver:
  • 5 Answers
This sounds like you have the "Weather Alert" function turned on. With this on, the radio will check for an emergency signal on the weather channels about every 10 seconds.
Posted on Apr 10, 2011
My ac works good the compressor cycles on n off real. Cold about 10 miles of driving the ac clutch turn off for about 15 seconds the it start working good what the problem
there's a pressure switch on the receiver/dryer tank on your system id bet , this is momentarily shutting off your compressor clutch as the receiver tank is being pulled m/t of refrigerant , this most times is an indicator of a small hole in system and some of your refrigerant charge has leaked out , a pressure gauge would confirm this
note: automotive ac systems possess high pressures that can seriously harm anyone that opens the "wrong" line
always obtain a good tech's help if your knowledge is not enough on this
Oct 13, 2015 | AC Cars & Trucks
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
What causes the sound to cut for a few seconds?
Hi i just would to know if you did try to connect your TV by HDMI to test if your optical output of your reciever/amplifier have some problem. In second time yes maybe you can have an overheating problem, just take a look at your grid and maybe a clean-up will be necessary. I don't think your amplifier have a fan.
Don't hesitate to contact me here in this post. have a nice day.
Nov 10, 2014 | Technics SA-DX750 Receiver
There is no reset button at the bottom where is it?
Hi cloriaj,
There should be a reset button on the back righthand side of your unit.
The Garmin Nuvi 205W and most other 200 series GPS receivers are normally reset as follows:
The reset button is located on the right rear-backside of the unit. Press a blunt non-metallic object or a cut off toothpick into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by sliding the Power key to the left for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
It would be best to assure the unit has external power, and hopefully a full battery charge, for best results. Also you can download a complete manual from this link for more info:
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Let me know how this turns out, and if I can help you further.
Regards,
Bill
Sep 19, 2010 | Garmin nuvi 205W GPS Receiver
Won't turn on - when last used 7 days ago was working perfectly.
Hi davisfive,
The Garmin Nuvi 250W and most other 200 series GPS receivers are normally reset as follows:
Regards, Bill
Sep 19, 2010 | Garmin nuvi 250W GPS Receiver
My gps will not turn on
Hi undten,
I wonder what's going on with all the Garmin reset and failure to powerup problems during the last few days...it must be the water...
Try these steps for powering up and resetting your unit.
The Garmin Nuvi 265 and most other 200 series GPS receivers are normally reset as follows:
Regards,
Bill
09-19-10
Sep 19, 2010 | Garmin nuvi 265 Car GPS Receiver
I have just changed the batteries in my key fob for my P reg. ford fiesta but it won't open the doors
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3-5 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds
Jan 16, 2010 | 1995 Ford Escort
Remote contoller mode light flashing controller not working?
Hold down the connect button on the receiver and the mode button on the controller at the same time for approximately 10 seconds. This is a 2.4 GHz wireless transmitter and receiver (connection is somewhat like your WIFI router and laptop computer) and they need to reconnect sometimes.
Dec 31, 2008 | Logitech Cordless Action Controller for...
Sound problem
I'm fairly certain this is a cable signal issue... I have had my digital audio cut in and out and the cable company traced it to a weak signal and replaced the cabling. No issues since. Just an FYI, my setup is a Sony 6.1 with an Optical cable. There is a Blue Light indicator for Surround and when I had the problem, the receiver's light would go off and the display "blinked."
Dec 17, 2006 | Aiwa AV-D57 Receiver
ICOM Informatique IC-A23 VHF NAV/COM Air Band Transceiver 2-Way Radio Logo
121 people viewed this question
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
BJ Russell
Steve
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
