Question about AEC Software Nuance Dragon Naturally Speaking 10 Legal - Upgrade from Professional Upgrade Version for PC
Can't install dragon naturally speaking...processor too slow
When I tried to install Dragon Naturally speaking 10 on my hp pavilion dv9000 it said tha processor speed was not enough to run the program. My alptop is only 1 yr old and should support the software any suggestions.
  • pmedic12 Oct 07, 2009
    Thank-you for your prompt response. I have figured out the problem...I was on the power save setting and the processor was set to work at a lower speed.
    Thanks,
    Dan
  • AEC Software Master
  • 3,287 Answers
Unfortunately, a "one year old notebook" doesn't guarantee minimum hardware compatibilty of the Dragon Naturally Speaking product. Notebook computers are usually less powerful than their desktop counterparts largely in an effort to extend battery life. Amazon.com lists the following hardware requirements:
Recommended Specifications: CPU: Intel Pentium / 2.4 GHz processor (1.6 GHz dual core processor) or equivalent AMD processor; Memory: 1 GB RAM; L2 Cache: 1 MB
The link for the amazon.com web page containing the information above is provided below. Does your notebook meet the above specs?
http://www.amazon.com/Nuance-Communications-Inc-A109A-G01-10-0-NaturallySpeaking/dp/system-requirements/B001B5J7LQ/ref=noref/176-6023948-4816737?ie=UTF8&n=229534&s=software
Posted on Oct 07, 2009
  • Steve Oct 08, 2009
    Great - I'm glad you solved the problem. Most software is not returnable once opened, so your money didn't go to waste on a product you might not have been able to use.
    President:
  • 3,278 Answers
Hello !
According to the specs for the software, the AMD Athlon 64 1 GHz processor is the minimum requirment. Your system has a faster processor (AMD Turion 64 X2- as far as I can tell). So, your processor should run the Dragon software.
I'd suggest selecting Control Panel - Device Manager and right-click on the processor. Check to see if you do have that processor. If so, update the processor driver software.
If you still have your paperwork when you purchased the system, the processor should be listed. If the processor you found does not match the processor on your paperwork, contact HP.
Hope this helps.
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Apr 25, 2013 | Nuance Dragon Naturally Speaking 11 Home
Can Dragon 10 be installed on Windows 7, 64 Bit?
Apparently you need update 10.1 to work on a 64 bit system. Check this out: http://community.nuance.com/blogs/dragon/archive/2009/03/25/dragon-preferred-and-standard-10-1-updates-for-vista-64-available-in-english.aspx
Feb 03, 2013 | NRS Nuance Dragon Naturally Speaking 10...
I just bought naturakl speaking 11.5 home. how do i download it/
Dragon Naturally Speaking 11.5 FULL
If you already have a premium key,
Click here
Aug 29, 2012 | Nuance Dragon Naturally Speaking 11.5...
Dragon Naturaly speaking XP editions not finding audio and video cards
and we can assume your computer is running xp correct? If not, then you'll need the updated Dragon, naturally speaking
May 29, 2012 | Dragon Systems Nuance Dragon...
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
Jun 05, 2010 | NRS Nuance Dragon Naturally Speaking 10...
I need the manual. Bought for me but no manual in
You may try contacting ther manafacturer to get a new one. They may even have a digital copy that can be downloaded.
Mar 31, 2010 | Dmm Nuance Dragon Naturally Speaking 10...
I dont have dragon naturallyspeaking serial no.
The serial number can be found on the sticker on the back of the white envelope of the dragon disc.
Mar 14, 2010 | Dmm Nuance Dragon Naturally Speaking 10...
Cannot uninstall dragon 10
I CANNOT UNINSTALL DRAGON 10 FROM MY COMPUTER TO INSTALL TO ANOTHER
emailmirella@gmail.com
Nov 15, 2009 | RTO Nuance Dragon Naturally Speaking V10...
AEC Software Nuance Dragon Naturally Speaking 10 Legal - Upgrade from Professional Upgrade Version for PC  Logo
305 people viewed this question
Top AEC Software Computers & Internet Experts
David Payne
David Payne
Are you an AEC Software Computer and Internet Expert? Answer questions, earn points and help others
