Question about Sewing Machines
I have a countryside 3500P multifuel pellet stove. Last spring while in operation the auger stopped turning. I checked all the electrical connections and as far as I can tell all is working. Gave it a intensive cleaning but still no luck. I have owned the stove for 7 years with no previous problems. Not sure is small appliances is the right category.
  • 2gieses Oct 12, 2009
    Yes it was helpful. Stove is up and running, Thanks.
    President:
  • Sewing Machines Master
  • 1,723 Answers
Inside where the auger motor is, there are some thermostats on the side of the fire box. One of these controls the auger motor. It has a very small little reset button on it that you have to press to reset. That will bring the auger motor back to life for you!
Posted on Oct 07, 2009
My new Bernina 880 will not turn on. I have been using it daily for the past week. Last used yesterday afternoon. This morning it will not turn on.
You might try a different electrical outlet in the house or check the one you plug your sewing machine into to make it is still working. Hopefully, there wasn't an electrical surge.
Apr 18, 2018 | Bernina Sewing Machines
My machine won't stop running when turned on
Since you turn it on and it starts to run without your help the foot control has a problem. Try to pull the control apart and turn it on again. It is likely the spring is either broken or dislodged from where the bracket is. Check the spring.
Aug 13, 2015 | Husqvarna Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
For the last few days my aurora ,430 will go about 20 stitches then stop saying a thread broke. I have changed everything, cleaned everything, turned off and restarted everything, reset everything... you...
Sounds to be that the "check spring" came out if its "flag". Not sure if you want to take it to your repair shop or do it yourself.
Remove side panel/head cover/ end cap.
When threading the machine you thread the check spring when you bring the thread down and up.(sorry I just cant think of a better way to discribe it).
Find the check spring.
There should be a small black plastic part that the check spring is controling, and my guess is that it has came out. This is a comon problem with this machine.
I know this is a horable explanation but this is hard to discribe.
Hope this helps
Apr 01, 2011 | Bernina Activa 140
My Husqvarna Emerald continuse to stitch after I release the foot pedal. Although the stitching is at a greatly reduced speed it won't stop unless I turn the machine off.
It sounds like the food pedal is sticking. I have had this happen only to find that the pedal had drifted under my mobile thread drawer and was unable to lift up when I took my foot off it - yikes - looked like a ghost was operating my machine! However, it you are sure the foot pedal is not stuck under a piece of furniture, perhaps the spring inside is not decompressing completely. It needs to be checked. I am not that familiar with the Emerlad models - do they have a Stop/Start button on the machine itself? If yes, perhaps this button is stuck in a little? Check that also.
Jan 13, 2011 | Husqvarna Viking 1
Machine stops and says thread is broke. Mean while the thread is not broke
Probably one of two issues. There is a sensor in the upper tension that is operated by the check spring assembly. If its broken, twisted or jammed it will sew a few stitches, maybe more and then beep and stop. A service man is the only fix, sorry.
Derek
Nov 30, 2010 | Husqvarna Designer I
My sewing machine doesnt stop when I take the foot from the pedal what to do?
Your electronic foot control spring might be stuck or needs replacement.Precaution is needed in servicing this footcontrols due electrical shock.Often electrical lubricant is needed to loosen the tracks of the control brushes.Observe these possibilities,spring or dirty control brushes.
Nov 25, 2010 | Janome Memory Craft 9000 Computerized...
We have a Huswana snowblower and the auger does
Sorry, your problem was posted to Sewing Machine category. If you are still having problems, you mnight want to re-submit to another appropriate category for help.
Dec 30, 2009 | Husqvarna Designer I
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
