Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Light comes on and turntable spins. It sounds like it is working but no heat.
  • 11,896 Answers
Inside the machine is a fuse that is expressly for the magnetron tube. You may or may not have special screws that hold the cover on, but usually they are the tamper - proof kind, you Can buy the tool that removes them. The fuse will be a small (1/4"x1 1/4") AGC type and will be white ceramic with a metal cap at each end, this too, you can buy. After replacing the fuse, make sure that you put the cover back on before testing the ' nuke '. The special tool ( if you have to buy one) and the fuse will cost far less to purchase than a new unit. If the unit still doesn't heat, then the problem will most definitely be in the mag circuit. To replace the entire unit would be my best advice, to repair it costs more than just money, you also have to hassle with the repair people and lose out on time not having your 'nuke'.
Posted on Oct 07, 2009
Why does the turntable spin when the door is closed ?
this is normal thats the way they heat from in to out
now if you open the door the light is on
if it does not just change the bulb 10w 120 vac e14
Sep 16, 2015 | Microwave Ovens
Kenmore microwave 72169122010 turns on but wont heat or spin turntable?
Door sw 'turn on and push up and down on the door it make come on
Oct 15, 2014 | Microwave Ovens
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat. The light comes on the turntable turns
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./,/,
May 16, 2010 | Maytag MMV4205 Microwave Oven
Light and turntable work, but it won't heat
There is a fuse in this microwave.The fuse is difficult to get to.
But i do not think it is this fuse.You have lights and the carousel
spins.This sounds like the thermostat or the magnetron tube that
creates the heat.
Feb 02, 2010 | Maytag MMV5156A 1000 Watts Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
Samsung microwave oven turntable doesn't turn now. Is it ok to still use to heat/cook food ? What is the problem with it ?
Yes it just will not cook or defrost very evenly. It is not dangerous however.
Probably the motor or gears that make the turntable go are worn or burnt out.
May 01, 2009 | Samsung MU3250W Microwave Oven
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
98 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
