Question about SanDisk Sansa c200 MP3 Player
Not showing in my computer when connected to my pc.Givng an unknown message when refreshing database if i insert a micro sd card
    President:
  • 2,923 Answers
Have you tried using another MicroSD? If not try using another memory card, but if you get the same problem, then the problem has something to do with the program and you need to contact the manufacturer to reprogram it.
Have a great day!
Posted on Oct 07, 2009
Micro sd card won't work on my compaq nc6120
Not sure if you formatted it on a game system but if you did, it will have to be reformatted. Did you click "Computer" (on pc) abd explore to see if it shows up there. Try right click refresh as well.
Nov 12, 2011 | Computers & Internet
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
It might be a dump question, but what do you have to do to see your micro sd card in the player? When I inserted the micro sd card, the player said "refresh database" but then I could not find the card...
Power up the player and goto settings scroll to info push enter.. This will show you how much info is on the player and the card plus the free space on both....push menu button again and scroll to music or whatever video, voice,,scroll to artist push enter... Look here for your files check where it says Unknown....If you still can't fine your stuff take out the card connect to the computer format the player when finished put the card back in and you will only have that info on the player.....When putting music or any file on the player make sure they are not hidden files......Open explorer goto tools scroll to folder options click on view click do not show hidden files or folders.....If your files are hidden right click on file click property you will see attributes remove all checks click apply....
Apr 30, 2009 | SanDisk Sansa e260 MP3 Player
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Refreshing database - Everytime
It's only reading the data on the micro sd, it just has to have that little time to do that, even if there is hardly anything on the sd, it still needs to check it out, just like it does with its own drive. Don't seat it, if you don't like it see if you can put the data onto the main drive of your sansa.
Feb 06, 2007 | SanDisk Sansa e200 MP3 Player
How do you refresh database?
This just means that the player is refreshing the songs on the list, it does not mean that you have to do anything.
Feb 02, 2007 | SanDisk Sansa e250 MP3 Player
Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
229 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
