Question about Mitsubishi VS-50111 50" Rear Projection Television
My Mitsubishi vs-50111 has green, red arced line at top and bottom with double vision like suddenly. Any ideas?
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 07, 2009
I don't have manual for my Mitsubishi HD1080series model# VS-50111. I accidentally while in menu locked out front control panel
My sound is not working on different channels any idea ?
Jan 25, 2013 | Televison & Video
There is double text in red and green.
u have bad convergence ic , this parts is easy to located there 2 big black peaces the parts # start with stk , u have to do alot of soldering connection , or u can hire a tv tech and paid about $200
Nov 03, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I have Hitachi 50GX30B tv suddenly started to give green-red double vision with arcs On top and bottom of screen What is the solution?
The tv have a problems"Known as a Convergence problems"it,dead.The tv convergence board reqiure changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 19, 2010 | Televison & Video
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi vs-50111 Short Protection circuit How do I fix this
I need more detail of what the problem you are seeing if your getting red blinks or anything put in more details
Jan 18, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Mitsubishi VS-50111 50" Rear Projection...
All three colors are off by an inch or two can i fix it or is this a pro's job
The Convergence Circuit has failed and a Professional would be needed to fix it.
Hope this helps,
Skyassoc
Jul 16, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
