I have a Goodman GMPN120-5 furnace that has flame rollout. The filter is clean,the flame is blue,induction blower works fine. Any suggestions?
    President:
  • 3,433 Answers
I hope this helps you_Ned
http://www.fsti.com/rollout.htmd
Explains flame roll out. :)
Posted on Oct 07, 2009
Top rollout switch triggers with blinking code *6*, Furnace only runs with cover off
restart unit as soon as your inducer fan came on pump the 2 wires to pressure switch and wait to see how long it stay also watch the flame at the burner
Jan 27, 2014 | Goodman GMS90703BXA Heater
I have a goodman gmpn that the middle burner has a little bit of flame rollout it kicks the flame sensor switch after about 1-2 minutes then it will not cycle back on. The flames are perfect until the main...
Unfortunately that means there's a hole in the heat exchanger, particularly in that cell of it. When the main blower comes on the air is pushed into the heat exchanger, causing the flame rollout. A heat exchanger crack or blowout is usually what condemns a furnace for good. Goodmans however, have a lifetime warranty on their heat exchangers, so you'll probably be able to find someone to replace it pretty cheap, or do it yourself for free.
Nov 04, 2011 | Goodman GMS90703BXA Heater
I have a Goodman GMH95/GCH9 furnace. The blower runs but no flame. LED is on (normal operation) checked fuse ok. held down fault button-6 flashes. didnt look like the draft blower turned on when a call for...
Hello, you can check the resistance of the motor by turning power off to the furnace and disconneting tje two wires which go to the motor. Take a meter and check the resistance, you should have resistance, if not the motor is bad. A rollout switch is a normally closed switch so you will chevk its resistance aswell, if the switch is open that signals a problem with the burner flames and you not read resistance. If the switch is closed and good you will read resistance.
May 01, 2011 | Goodman Heating & Cooling
Furnace was working fine and just stopped working...it reacts to raising the thermostat but doesnt actually flame on
This is probably a ignitor.
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Please leave feedback... Thanks...
Jan 28, 2011 | Goodman GMS90703BXA Heater
Rollout switch continues to trip
If you have a cracked heat exchanger this will cause the flames to rollout and trip this switch. Its meant to stop the furnace from running and putting carbon monoxide in your home. Watch the furnace as it tries to light if when the gas valve opens and flame is established it should go into the tubes heat the heat exchanger and then your main blower motor will come on. When your main blower comes on is usually when you see the flames rollout and trip that switch. If this happens you can either buy a heat exchanger or new furnace if its a older unit Obama still has that awesome tax credit til 12-31-2010.
Dec 13, 2010 | Goodman Heating & Cooling
My York furnace is giving the error message for "rollout switch open"...when it does that, the flame does not ignite and the fan blows cool air. However, if I remove the panel from the furnace,...
Roll out switches are sometime wired together with limits. Lack of air flow. Limits reset themselves and roll outs have to be manually reseted. Could be dirty blower,a.c. coil on furnace, or filter.
Jan 05, 2018 | Heating & Cooling
Having a problem with a goodman gas furnace, pilot starts and burners fire up, blower starts and burner goes out after like 5-10 seconds. Blower continues to run but only circulates cold air. burner does...
Sounds like the rollout is being tripped from the blower moving the falmes. i would have your heat exchanger checked for cracks or holes as this is usually the reason the blower moves the burner flames to tripp a rollout.
Feb 22, 2010 | Heating & Cooling
I HAVE A YORK STELLAR PLUS,MODEL PEUDD12N09501C 15 YEARS OLD. THE AIR INDUCTION MOTOR RUNS FOREVER. THE AIR INDUCTION MOTOR COMES ON , THE THE THERMOSTAT CALLS FOR GAS, THE IGNITOR LIGHTS THE GAS, FURNACE...
Check the filters first, then check for blockage in the return or supplies. An easy way to do this is by putting your hand in front of the vents to make sure accurate airflow is there. Your furnace has limit switches on it that detect heat, and if heat is getting trapped inside the unit to much, you will trip these switches and the blower will just run forever. Then you have to reset it or wait forever. But try those few things first. Hope this helps.
Nov 26, 2009 | York Yankees Bedding MLB Comforter
Where is the heat sensor on a goodman furnace
Heat sensor....Or a flame sensor. Flame sensor is connected to a "single" wire under the buners usually found on the left side. Heat sensors (or flame rollout switches) are found surrounding the burner box. The most common bad one will be located just above the burners. it "should" have a small reset button in the middle just between the two wires. If the furnace does light even for a short time the rollout switch is not bad.
Mar 03, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
351 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
