Question about Singer Tiny Serger TS380
Where can I have this repaired. it was soaked in
Where can I have this repaired in the Philippins, it was soaked in flood waters
HOW TO SET COLORS IN FABRIC
You can soak the fabric in vinegar and salt water... Gently swirl the fabric around in the solution, change the water with fresh water, and if the colour still comes out, drain and repeat as necessary until the colour stops coming out.
Apr 21, 2017 | Sewing Machines
How do I unlock a1979 singer sewing machine
oil it as best you can and wait till it soaks in a few days . if you can not rotate the hand wheel then take it to a repair shop.
Aug 23, 2015 | Singer Sewing Machines
What to feed a snail and how to feed a snail what is good for it and what is bad for it
Snails are vegetarians, Depending on the kind of snail it is. If it is a land snail.... tomato, lettuce, etc. If it is a aquatic snail, get some sea weed, and other types of green stuff from the local river. (let it soak in clean water)
Oct 05, 2014 | Sewing Machines
Manual free download
Hello
It is available as follows
Model Lang Title Date Huskystar 207,Huskystar 215 Svenska Instruktionsbok 04/28/2010 0MB Huskystar 207,Huskystar 215 Espa?ol Gu?a del usuario 02/01/2010 1MB Huskystar 207,Huskystar 215 English User's Guide 11/24/2009 1MB
from this link
http://manuals.husqvarnaviking.com/
Hopefully this will be of some help.
Sewingirl/
Jan 28, 2014 | Husqvarna Huskystar 215 Sewing Machine
I have a 6440 from 1976. It was my mother's. Everything spins, but the gears aren't connecting and the needle isn't moving at all.
I think it is bobbin winding mode. Take a look at the hand wheel, check for a inner knob and turn it the other way. Sometimes on later models it was a switch type thing you flipped.
Now... lets talk about WD40. WD stands for water displacement. It is NOT a lubricant. When it\'s all freed up in there... wipe that stuff out and oil. DO NOT LEAVE THAT stuff IN THERE.
Dec 15, 2012 | Husqvarna Viking 1
How to repair the bobbin winder on the singer cg550
if you have a top bobbin winder that is jammed the only way to f ix it if you can't replace it is to put some WD40 on the spindle and let it soak down then put an electric drill over the spindle and switch on slowly and it should free off, if it just not catching to wind a bobbin you may need to replace the winder rubber which means getting inside the machine
Sep 05, 2011 | Singer CG550 Mechanical Sewing Machine
I have a Janome Decor 5018 that was given to me as a gift, as well as a Janome New Home D104 serger. They were both damaged in a household flood and I'm looking for retail prices on them both to turn over...
At www.sewingmachines.com They had one listed for 399.00, and said manufacturer's retail was 549.00. Take care and good luck sorry about your flood, Andy
Mar 09, 2011 | Janome D'cor Excel 5018
Lion Brank Nature's Choice Organic cotton sheds like crazy. What do I do? Made a beautiful baby blanket and afraid to give to the mommy, baby will end up with a mouthful of cotton.
You may want to soak the (finish product) of the blanket in a warm soapy water (bar/bath soap is prefer). Let it stay for about 20 minutes or so. Do not wring or dry it in the machine. Use a fresh towel. Lay the towel on flat surface. Put the wet blanket on top of towel. Roll the towel together with the blanket and add a little pressure to the roll to get the excess water out of the blanket. If still need it take another fresh towel and do it the same way. Then, lay flat to dry. Warm water and soap usually will make the fiber to be less sheds. Good luck!
Aug 02, 2010 | Lion Cotton Yarn
Changing light bulb on viking designer 1
when one faulty, both do not work. replace faulty one & both will then work.
Jun 19, 2008 | Husqvarna Viking 1
Sewing Machines Logo
15 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
