Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser sticks open on model TFX25ZPBEWW
  • GE Master
  • 4,654 Answers
If you unplug the WR57X10026 Twin Water Control Valve on the rear of the refrigerator near floor will the water flow stop. Then plug that back in and unplug the refrigerator doest the water stop? I need to find out if the water control valve on the rear of the refrigerator is leaking while turned off or if the dispenser control board is sticking with the power turned off. Your model comes with 2 different choices of water control valves.let me know Thanks, Sea Breeze
Posted on Oct 07, 2009
The detergent door will not open on Electrolux model fbd2400kb8b Soap does not dispense
It may be sticking from soap residue, pour boiling water slowing into the dispenser and see if that clears it. Be careful
Feb 16, 2017 | Electrolux Dishwashers
Why is no water being dispensed by the dispenser?
The solenoid that allows water to be dispensed is not opening fully.
Could be sticking or is faulty and needs to be replaced.
Jul 19, 2015 | Refrigerators
Ed5shaxmt10 water dispensing won't shut off
One of two problems could be causing this problem...... First problem can be that the switch that you push on to dispense water or ice is sticking. The second problem that could be is the water solenoid that comes on and should close off fully is sticking open and allowing water to drip and not shut off completely. This is usually caused when the plunger in the solenoid starts to stick due to calcium deposits that has built up on it after time and if the water dispense system is not used that often. If you're not technically inclined, make sure that the repair person does not tell you anything that does not fit the descriptions that I have mentioned above. Hope this helps.
Mar 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
How many cu ft is it?I have a tfx25zpbeww
The number in the model number is the cubic foot size. In this case, between 24.5 and 25.4, so it is called a 25 cubic foot model.
Jun 19, 2010 | GE Profile 21.6 cu. ft. Side-by-Side...
Whirlpool side by side with a broken water dispenser
you may have a sticking water lever or a bad water valve.
the lever can be changed from the front and you should know if it sticks.
the water valve can be replaced from the rear of your unit. it is the plastic part where the water line hooks up to the unit.
Jan 03, 2010 | Whirlpool GS6NBEXR Side by Side...
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
Water dispenser
This sounds like the microswitch that is activated by the paddle is sticking . If all the other functions appear to work ok ?? Does this particular model have an ice and water dispenser ?? Does the ice behave in the same way ? if not then i would suggest that the water valve is not closing and needs replacing instead of the microswitch
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser conditnues to drip after releasing the button
No seal or gasket on the water line... you do have a water valve that maybe sticking open .... and/or the switch in the water dispenser is stayng open...hope it helps let me know..
Jul 22, 2008 | Sub-Zero 695/O Side by Side Refrigerator
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
252 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
