Question about Refrigerators
My refridgerator wont get cold and i keep hearing a clicking noise as if the dfrost timer or some type of timer is not switching to cool mode
    Sergeant:
    Champion:
  • 257 Answers
Not a expert just trying to help,, if you are hearing a clicking noise then timer stuck,,most models timer is in the back(may have to take panel off) to see it,it will have a slot in it try turning it and see what happens,, if no good need to replace it,, hope this help you
Posted on Oct 07, 2009
Bosch KAN62V40AU not freezing or cooling
do u hear the compressor running? hear any clicking? IF NOT CHECK THE defrost timer also called cold control thermostat for continuity and voltage with a multi meter. u can place a small philips screw driver into the small hole under the timer and turn clockwise slowly till u hear 1 click which will take it out of defrost mode. u should hear the fan and compressor come on. let me know if u need more help
Mar 11, 2015 | Bosch Refrigerators
When i start my vehicle when it's cold and turn on the dfrost it does not clear the windshield
I would suspect you have the controls set for defrost, if no hot air is blowing from vents, you could have a blend door that is not functioning, switch from defrost to panel to floor and listen to hear blend door moving, if you hear the door moving...do you have hot or warm air on any other setting? if not check the antifreeze level under the hood, some vehicles can be very finicky even if a little low on antifreeze. DW Mylin
Nov 24, 2012 | 2005 Pontiac Aztek
The freezer keeps defrosting.....starts to cool down then back in defrost mode again. Also the bottom of the fridge is not keeping things cold anymore. Could you please help me on what could be...
the defrosting mode could a problem with the defroster timer. as for the bottom one if the top is not cooling the bottom one wont either. the freezer fan is what also keeps the bottom frig cool. the defrost timer should be on the bottom frig close to the ligth.
Jan 19, 2011 | Whirlpool ET8FTEXM Top Freezer...
Refrigerator is making a clicking noise, wont get cold, light flicks on and off when it clicks. ge refrigerator model # gdl2okcsabs
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Refrigerators
Reseting
The only reliable reset on a refridgerator is at the defrost switch. Remove the front bottom panel from your fridge and you'll see a small clockmotor with a couple wires leading to it. In the center of this you'll see a screwdriver slot. Turn the knob very slowly to the right(clockwise) until you hear a click, do not turn the slot counterclockwise. Once you've done this, check for cooling in the freezer part. It should take about five minutes till it starts to cool. If this solves your problem, than the defrost timer should be replaced. Thank you, Dana
Feb 02, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water is leaking from freezer into refridgerator plus there is alot of frost in freezer
Your drain is probably blocked from ice because it isn't defrosting. To make sure the heater hasn't failed try doing the following.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Oct 09, 2009 | Refrigerators
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Refridgerator is not cold enough
Most likely you have a problem with the defrost cycle, Find the timer and advance it unil it clicks.Then observe the freezer compart it should start melting the ice from the coils behind th back wall in a few seconds. if you cant see it you should be able to hear the crackling of ice if the door is open.
Mar 17, 2009 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
