Question about Amptron CMV-926D Silver (Black, Silver) 19 in. Flat Panel LCD Monitor
Monitor occasionally makes a "trilling" sound
When the computer processor is working hard I get a feedback sound out of my monitor speakers. A "trilling" sound is the only way to describe it.
    Scholar:
  • 88 Answers
Cheap sound card. upgrade to an audigy or even a sound blaster. You can try reducing the volume control on the internal mixer from all the way up to about 2/3 and that will help. If it's not up all the way on the main volume already- then the sound card is cheap- and has no filtering on the inputs. A better sound card generally fixes this.
Posted on Dec 24, 2007
How to build a or assemble a computer and troubleshoot?
Building a computer will require: a motherboard, a processor, memory, a video card or motherboard with onboard video, a sound card or motherboard with onboard sound, at least one hard drive, a CD or DVD drive, a case for the computer components, a power supply, fans to cool the computer, an operating system, a monitor, speakers, keyboard, mouse, 2-3 hours to assemble the computer.
You must ensure that all of the components are compatible with one another. After receiving the parts, lay everything out on a large, clean surface. Make sure you are grounded by touching a metal surface; this will prevent the transfer of static electricity to your computer components.
Typically, the steps to install the components are as follows: 1. mount the power supply in the case, 2. mount the motherboard 3. lock the processor in the socket on the motherboard 4. insert the memory sticks into the slots on the motherboard 5. mount the processor fan on the processor 6. insert the video card into the applicable slot on the motherboard 7. insert the hard drive into a hard drive bay in the case, 8. insert the CD drive into a CD drive bay, 9. mount any fans you have to the fan cutouts on the case 10. connect all applicable data cables to the CD and hard drives 11. connect all applicable power cables to the motherboard, video card, processor, hard drive, CD drive, and any other components. 12. connect the front panel USB, power, lights, and reset connectors to the motherboard 13. close the case 14. connect the power, monitor, speakers, keyboard, and mouse to the computer
Because this process is rather involved, I recommend following a guide such as this one: http://www.maximumpc.com/article/how-tos/how-_build_silent_gaming_pc
It details the process, includes pictures, and even provides a list of compatible parts.
Jun 19, 2011 | Computers & Internet
How do i get the sound to work on my HPw2207 monitor? Are there built in speakers?
HP w2207 has built-in speakers (Integrated rear facing). All you have to do is connect the LCD and PC (Sound output) using Audio Cable (Stereo).
For further information you may refer to HP w2207 User Guide (Page-19)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Feb 04, 2011 | HP w2207 Monitor
Speakers causing computer problems companion 5
Hi, I have these also & mine occasionally go to the red light while the PC is on.. Are they visible in the 'Sound' in control panel as Bose USB Audio' is this set to default? Is the USB kept in the same socket? & are they too close to other speakers?.. Let me know
Mark
May 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Speaker is not working properly , rattling noise coming
Can you hear any rattling inside if you shake the monitor? It can be blown speakers or they are being driven too hard, just want to make sure before taking it apart. Do not expect too much sound from monitor bulit-in speakers since they use very small speakers that sound like tin can for most application.
Apr 16, 2010 | HP w17e Monitor
Hi, my Dell Vostro 200 monitor isn't working; when I boot up the light is blue and everything else seems to work but the monitor says 'Entering power save mode' or something and it shuts off. I can't get...
Your monitor is most likely fine. That message is the monitor telling you it's not getting any video signal from the computer.
If you're hearing all the sounds that go with a normal startup (usually a beep from the motherboard, then hard drive activity, finally the normal Windows startup sound through the speakers), and seeing that message, then you may have a monitor problem. You can try another monitor as a test.
The trouble is probably that the computer is turning on, but not actually starting up. This may be due to power supply, memory, processor or motherboard problems. Or one of the drives or expansion cards connected to the motherboard may be keeping the system from starting.
Make sure the memory modules are firmly seated in their sockets, and disconnect everything else but the power supply. If the motherboard, processor and memory are working, the system will start and you'll see something on the monitor. Then you can start reconnecting parts and see when the problem returns.
Mar 30, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
Hi everyone, i am a vcliast and have been singing
The speakers MUST be in front of and pointing away from the microphone.
I don't know what you mean by "crystalized" as that mic is a dynamic type.
If the speakers are in back of you you WILL get plenty of feedback. If you must run that way, then you need an anti feedback processor. The device shifts the pitch slightly so that feedback can't occur.
Feb 28, 2010 | Portacom Porta-Com COM-60FC 6 Headset...
Can't get sound on monitor
First make sure that your speaker wire is plugged in to the correct port on your computer.
The speakerwire should be plugged into the green port.
Then make sure that the volume is turned up on your monitor.
Then on your computer.
If this is isolated to only your new monitor and the above solutions do not work there is likely a problem with your new monitor's speakers.
Cheers!
Feedback is appreciated!
Dec 30, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Feedback sound
If moving the microphone doesn't work then suspect "microphonics" where a loose electronics component is vibrating and acting as a microphone. Could be cable. Unplug all microphone cables, still feedback? Right click speaker icon, sound properties, temporarily disable computer sound input devices. If still feedback then analog section of sound card (or motherboard sound chip) or your speaker system.
Oct 15, 2009 | Altec Lansing Multimedia Computer Speakers
THERE NO SOUND COME OUT FROM al1717b monitor?
Did you getting sound through headphone?
if it is ok means your monitor speaker have problem or the speaker wire damaged.Open the case and check whether wire damaged or the continuty of speaker is not ok by using a multimeter.
Pls feedback.Later i get back to you.
Aug 24, 2009 | Acer AL1717B (Black) Monitor
Computer Will Not Boot
It sounds like it could be your processor, how did you test your processor to make sure it worked correctly? Also how manny stick off RAM do you have and the total amount in MB or Gigs.
Jan 22, 2009 | Intel Foxconn Motherboard
Amptron CMV-926D Silver (Black, Silver) 19 in. Flat Panel LCD Monitor Logo
76 people viewed this question
Top Amptron Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
