Question about RTO Oar Sockets
How to change impeller on 25 hp mercury efi four stroke
1986 mercury 50 hp 3 cyl 2-stroke stop running when is hot no more spark
The electronic module is protecting the power head from overheat damage. The motor is running too hot. you need to replace the water pump impeller.
Jul 02, 2018 | Mercury Boating
2009 mercury 115 efi four stroke giving 7 beeps and will not pass 2200 rpm, what is wrong?
urns out, though, the magic word in the search appears to be "six" beeps and then some things popped up.
A bit of info out there, but from what I can gather, it needs to go to the dealer for diagnostics.
Please let me know if there are any other ideas or thoughts with this particular engine.
Nov 12, 2017 | Mercury Boating
I have a 20 hp mercury outboard serial#06082001.I want to know what year it is and if it's 2 or 4 stroke
If you drop the first zero it would put it at 1981.
http://www.themarinedoctor.com/msn.pdf
this site gives a different answer, as 1980- 81, so close. It SUGGESTS it is a 4 stroke engine.
http://www.boats.net/parts/search/Merc2/Mercury/25%20%282%20CYL.%29%282-STROKE%29%28International%29/parts.html
It is likely a 4 stroke, but I won't give you a definitive answer, due to the damage it can cause with a guess!
A four stroke running with two stroke oil will just smoke, but a two stroke with no oil will seize and leave you stranded on the water with a seized engine!
A four stroke engine has valves operated by push rods or a pulley and a chain, a two stroke just has a head. Take a look at the engine and it should be obvious.
For your first service, I would suggest you go to a marine engineer. Ask all the questions, and get the right answers. When I had my 1986 Evinrude serviced, i typed a list of questions and left the list with him. i asked him when I picked up the boat and wrote the answers down. The first one was 'petrol to oil ratio and which is the best oil'. A basic service will cost you a hundred bucks and you will have some comfort that you are unlikely to break down, 6 miles offshore with only a paddle :)
https://www.google.ca/search?q=20+hp+mercury+outboard+serial%2306082001&ie=utf-8&oe=utf-8&gws_rd=cr&ei=uwm-WKjHK6SUjwSApJLQBw#q=mercury+outboard+serial+number+lookup&*
Mar 07, 2017 | Mercury Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Jul 04, 2009 | 1999 Honda XR 600 R
Need oil change in water
If its a 2 stroke, there is no oil to change, if its a 4 stroke, you can pump the oil out with a small diameter tube pump.Depending on the motor, you can get it through the dipstick or the fill opening. If you need to change the gear oil, there is no way to change it while in the water. Stop by a marine supply store and get some oil absorbsion pads (diapers) in case you happen to spill any oil into the water
Mar 11, 2009 | Light Outboard Motor Boat Bass Fishing...
RTO Oar Sockets Logo
897 people viewed this question
Top RTO Boating Experts
merc racing
Level 1 Expert
Mike
ffstaffsta
ffstaffsta
Are you a RTO Boating Expert? Answer questions, earn points and help others
