Question about Dryers
Have a gibson dryer trying to fiqure out how to get in it to replace the belt.
  • Dryers Master
  • 7,482 Answers
If it is a front loading machine, most of the time you will remove the top, then the front of the machine to get to the drum and belt. If you remove the drum and belt, the that will expose the drum rollers, idler arm with pulley and the motor.
While you got the drum out, I would recommend that you lubricate the drum rollers at the shaft with a good grade of machine oil like 3 in One oil. It will save you noise problems later.
Good luck,
I hope this helps
Posted on Oct 07, 2009
How to put the belt on
You need to remove the drum in order to replace the belt so that you can inspect and grease the rear bearing. Once the belt is around the drum and you know the glides and rear bearing is in order you make sure the belt is not twisted. You move the idler to the right and run the belt over the top of it and under the motor pulley.
How to get into the machine:
Note: westinghouse frigidaire gibson and kelvanator dryers are all basically the same.
Jul 21, 2012 | Frigidaire Dryers
Tip
Gibson Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Gibson washer wont run after replacing the belt
I was looking for your brand and all I could find was this:
http://www.ehow.com/how_12108669_replacing-dryer-belt-ge-spacesaver-laundry.html
It may not be about Gibsons especifically yet, it's very interesting. Good luck to ya!
Jul 15, 2012 | Washing Machines
Gibson dryer will not spin
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Dryers
My gibson dryer squeks when first turned on for about 30 seconds to a minute....do I need a new belt?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Dryers
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture http://sites.google.com/site/sublimeappliancerepair/_/rsrc/1246721031553/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info/Norge%20dryer%20with%20drum%20removed.jpg
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
Belt: http://www.appliancepartspros.com/part_details.aspx?part_id=4043963&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d47809%26diagram_id%3d681078
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
http://www.appliancepartspros.com/part_details.aspx?part_id=4373393&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d49146%26diagram_id%3d673577
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Gibson heavy duty dryer. how do I open it up to replace the belt?
My drier is squeaking when first turned on.After about 5-6 mins.go by it is fine.
Oct 09, 2008 | Dryers
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
