Question about HP 83 3-ink Black UV Cartridge Multipack (C5072A) Printer
How to change cartridgeon HP desktop D4160
From HP's web site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00641960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Step one: Replace the old print cartridge
  1. Make sure the product is turned on.
  2. Open the print carriage access door.
  3. Wait until the print carriage moves to the right side of product and is idle and silent.
  4. Press down on the print cartridge to remove it from the slot, and then slide it out of the print carriage.
  5. Remove the new print cartridge from its packaging, and then carefully remove the plastic tape by using the pink pull tab. Figure 1: Remove the tape how to change cartridgeon HP desktop D4160 - c00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  6. Slide the print cartridge at a slight upward angle into the print carriage until it snaps into place. Figure 2: Insertinhow to change cartridgeon HP desktop D4160 - c00642241.gifartridge c00642241.gif
  7. Close the print carriage access door. WARNING: Keep both new and used print cartridges out of the reach of children.
  8. Wait until the print carriage moves to the right side of the product and is idle and silent.
Step two: Align the new print cartridge
  1. Load Letter or A4 size, unused, plain, white paper in the input tray.
  2. Open the printer Toolbox . Follow these steps to open the printer Toolbox .
    1. From the File menu in the software program, click Print . The Print dialog box appears.
    2. Click the Properties button. The Print Properties dialog box appears.
    3. Click the Features tab.
    4. Click Printer services . The printer Toolbox appears.
  3. Click Align the Print Cartridges .
  4. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and then calibrates the product. Recycle or discard the test page.
Posted on Apr 30, 2009
Where do I place the paper in a HPdesktopD4160
Posted on Sep 15, 2009
Change black 1400 cartarledge hp2100?
Posted on Oct 18, 2008
How do I check ink levels on my HP deskjet D4160 Printer
When your printer was installed, it came with a CD with a complete software package for your printer to report (ink levels/diagnostics/etc) to the computer. If it was installed in Windows 7 (and below) it would be found at "Start" (button) > "HP" > Deskjet D4160 > Deskjet D4160. In Windows 8 look for HP. Once you've opened the application it will query the printer for its status. One of the icons will show the "Estimated Ink Levels".
If you can't find the software installed or the CD you can find it at HP's (US-English) support page for your D4160 is at the link below. Persons from other countries you can find their language at HP.com/support. There you can find everything you need.
Ink Jet Notes:
·Printers can be set to "economy" (default or individual job) to save ink if high quality is not an issue.
·Follow the user's manual or print using all cartridges at least monthly to insure the cartridge jets do not get fouled with dried up ink. Once fouled its toast. I've never been able to clean one.
·New printers come with minimal ink in the cartridges.
·"XL" (high volume) versions of your printers ink cartridge is cost effective if you print frequently.
In His Grace
Elton
HP Support
Mar 03, 2015 | HP Deskjet D4160 InkJet Photo Printer
Can i use a #94 ink cartridge in a HP deskjet D4160 printer
No, you cannot, only 93: Tri-color, 98: Black and 99: Photo are compatible with this Model. Hope this helps. Good Luck.
Thanks for using FixYa.
Jul 18, 2011 | HP Deskjet D4160 InkJet Photo Printer
Hi HP deskjet d4160...runs the paper but prints either 1 line or nothing
It may need a new ink cartridge or the flat cable from the printer head is broken.
Dec 02, 2009 | HP Deskjet D4160 InkJet Photo Printer
Need software for hp desktop printer D4160
HP Deskjet D4160 Printer Basic Driver Installation Instructions:
1. Click on the Download Only button and a File Download box will appear.
http://www.nodevice.com/driver/Deskjet_D4160/get39222.html
Sep 10, 2009 | HP Deskjet D4160 InkJet Photo Printer
HP D4160 printing only in b & w. Changed color cartridge. Have I messed up a setting somewhere?
yes you must have messed up the setting try change the cartridge i mean swap it, black for colour and colour for black, if it does not work, then make sure you bought the right one check the numbers of the one you changed, if its thesame, then return the catridge there must be a factory error or the catridge is a fake one. thanks
Jul 16, 2009 | HP Deskjet D4160 InkJet Photo Printer
Changed cartridges, won't print, yellow arrow flashes
Generic cartridges can cause problems like this. Try using HP cartridges instead. If using HP cartridges, then try cleaning/aligning the print nozzle with the software that came with the printer.
Jul 08, 2009 | HP Deskjet D4160 InkJet Photo Printer
Deskjet D4160: ink smears all over the page
Please go to this link for detailed instructins from HP that should help you with your problem.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00640488&dlc=en&product=501857
I use only HP printers and their support has been very good for me.
Aug 06, 2008 | HP Deskjet D4160 InkJet Photo Printer
HP 83 3-ink Black UV Cartridge Multipack (C5072A) Printer Logo
214 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
