Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Pro Heat 9300 brushes won't turn before and after replacing belts
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dfghsdf
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
Bissell pro heat brush is not spinning. the belt is on and spinning but brush is not moving
There are two belts a brush belt and a pump belt. For a kit with installation instructions contact
BISSELL Consumer Services at
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 19, 2011 | Bissell Vacuums
Does the bissell pro heat have one or two belts?
The Bissell Model 25A3 has two belts, a pump belt and a brush roll belt. The pump belt (Bissell Part # B2150628) is flat and runs from the motor to the pump. The brush roll belt (Bissell part # B0560621) is cogged and runs from the pump to the brush roll. See key numbers 34 and 36 below.
May 17, 2010 | Bissell 25A3 Upright Vacuum
CANT FIGURE HOW TO INSTAL NEW BRUSH BELT
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hi There,
Here's a link to a video demonstration on how to replace the belt on your ProHeat carpet cleaner. This shows you step by step eveything you need to know.
If you haven't already purchased the belts, here's a direct link to the exact belt for your steamer. There are two belts on your machine, a pump belt, as well as the brush belt.
Bissell Pro-Heat, Pro-Heat 2 6960W Replacement Pump & Brush Belts
And here's the link to the video repair demonstration showing how to replace the belts on your Bissell ProHeat:
http://www.bissell.com/VideoRating.aspx?id=1555
I hope that this information was helpful to you. If it was, please rate the repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair.
Feel free to ask any follow up questions that you may have on this repair, I'm always happy to answer any follow up questions.
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell Pro Heat Carpet cleaner and the brushes will not turn. The pully is not turning the belt.
if the motor shaft that rotates the belt to turn the brush does`nt turn you have motor problem`s if it does you need to free up what ever is keeping the brush froom turning freely
Nov 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
789 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
