Question about Norcent Technologies LT-2025W 20 in. LCD Television
The tv has dimmed suddenly and the yellow color is almost completely gone. I have reset the color with no luck. Can I replace a bulb to fix this? If so, where can they be purchased?
  • 146 Answers
Not something you can replace yourself - your LCD uses a backlight - sounds like a bad circuit board - not really a backlight problem.
Try unplugging your unit for 10 minutes, plug it back in and see if that solves the problem otherwise you will need to get it repaired or buy a new one - don't attempt to open or repair yourself there are sensitive electronics inside.
Posted on Oct 07, 2009
Had tv fot about 7 years, at top center of screen an area has appeared that is yellow in color. How can I fix problem?
If it's a 3 tube projector, the front of some of the tubes are cooled by an oily substance. this oil is replaceable. If it uses a light bulb, the bulb can be dimming, the color wheel may need to be cleaned as well as the lenses in front of the light. The DLP chip can also be going bad.
Oct 25, 2016 | Televison & Video
Picture is dark
did u touch the lens or bulbs when u cleaned it? It could be a color wheel problem but i think u should try to reset light tunnel. Did it give you any warning? or did it just all of sudden go dim. I gave u a link to a trusted YOUTUBE tech.. i use his work all the time.
See if any blink codes come up if u disconnect a bulb..good luck
chad man
Oct 21, 2013 | Mitsubishi WD-73C9 73" DLP TV
SAMSUNG TV HL-85687W picture is dim
(Please check your model number - it appears to be incorrect, I believe it's HL-S5687W)
1) How old is the lamp? (how many hours on it)
2) Is the lamp an original equipment lamp, or aftermarket?
It's either the Lamp itself (it's not common for a sudden reduction in brightness), -or- the Lamp Ballast has gone bad. This is the power source for the Lamp, and although they usually die completely when they do go, sometimes they will act just as you have described... they fail into a "low power" mode.
If the lamp IS an original mfr lamp, and if it's nowhere close to being near "end of life", then I'd say it's likely the Ballast.
Prices for the original Samsung lamp run around $100 onamazon and others.
The Ballast p/n BP47-00037A has a cost of around $50 to $100 online.
Google those p/n in "Shopping"
The Ballast can be replaced without great knowledge, but will require some dis-assembly, and CARE.
WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such repairs.
Jan 12, 2013 | Samsung HL Televison & Video
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
Too much yellow in the picture...new bulb
hi, The only way you can fix that permanently is by taking the TV apart and doing some complicating soldering (the key thing in your description being that the menus come up green). For a temporary fix, try hitting or jostling your TV, because when it becomes normal it might stay normal until another large hit. Or try dampening vibrations by placing it on top of styrofoam or something. Better yet.... just go ahead and buy a new TV. thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | Televison & Video
We also have a greenish tint. We put a new bulb in because the box that said bulb needed replacing came up. We reset the tv but its still green. we have tried to adjust colors, temperature adjustment and...
Your "light engine has possibly gone down on you, did you replace just the bulb it's self or the complete bulb assembly? If you pulled out light assembly and replace just the bulb then repalce light assembly, if you repalced the whole light socket assembly and still have greenish color the you have a "light engine problem". Seek repair tech.
Oct 01, 2009 | Sony KDS-55A2020 55" Television
KDF 42E2000 dim
hello have you tryed going into the menu and click reset
shaun
Sep 10, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
DLP won't turn on, whinning noise
It takes a trained eye to see failure in the bulb. I susppect the lamo is gone. You hear the color wheel spin up and the lamp tring to arc. (crackling sound)
Jun 25, 2009 | Televison & Video
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
Norcent Technologies LT-2025W 20 in. LCD Television Logo
56 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
