Question about Thermador PGR366 Gas Kitchen Range
I am interested in buying a PRL366EH range but want to convert it to natural gas , is it possible
    President:
  • 1,304 Answers
Yes
you should tell your dealer you want it ordered set for natural
if they tell you they cant is a very easy conversion
the kit will be tapped on the back when you recieve it
Posted on Oct 07, 2009
How to change from natural gas to LP
Brian, You usually have to purchase a conversion kit for your make and model #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stove conversion natural gas to Lp
Range Conversion
How to Convert Natural Gas To Propane DoItYourself com
Converting LPG and Natural Gas Appliances
May 12, 2016 | Kitchen Ranges
Can I convert a 450rb from propane to natural gas
The simple answer is yes. However you will need to convert it. Simple process for a gas fitter, they will put a natural gas regulator on and possibly change the jets. Natural gas runs at a higher pressure than Propane. What ever you do, do not run without conversion, it will fail with possible fire or explosion.
Oct 04, 2015 | Kitchen Ranges
Convert propane to natural gas on tappan TGF657 range
go to hardware buy a valve for that type fuel and change them out
Feb 04, 2012 | Tappan TGF657 Gas Kitchen Range
Ge j2s968 convert to propane
On the back of the range there should be a conversion kit with intructions on how to convert from natural gas to l.p. good luck..
Nov 05, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven flame comes into the oven around the oven bake cover and all burners and broiler have a perfect flame. this is a brand new oven
Are you on natural gas or propane? If you are on propane did you have it converted form natural gas. Due to the difference in orface size you will be getting more gas flow then needed. If it was converted you need to contact the store and advise them it has a possible gas valve problem.
Jun 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Nov 21, 2008 | Cooktops
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Thermador PGR366 Gas Kitchen Range Logo
65 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
