Kodak EASYSHARE M340 Red 10.2 MP 3X Zoom Digital Camera - MSRP: $149.99
Problem for Kodak EASYSHARE M340 Red 10.2 MP 3X Zoom Digital Camera -...
My Kodak EasyShare M340 turns on, but then shuts off immediately.
By katelyn94xox on Oct 07, 2009
The battery is fully charged, and the camera is only a few months old. I press the power button, the lens fully extends. But then the light blinks red, and it shuts off. I've tried wiping down the battery and removing the memory card, but nothing seems to work.
Best Solution
posted on Oct 07, 2009
Very Helpful)
StephanSA
Rank: Guru  Kodak Cameras & Camcorders  Expert
Rating: 93%, 184 votes
There is a lot of advice I can give you mostly pertaining to the lens mechanism, but If it's a few months old , I would take it in as it probably is covered by a 2 year warranty depending on where you live.
Nevertheless , here are a few steps you could try if no warranty if applicable :
The problem is either something is jamming the lens , or that the lens sensor is faulty. This is a very , if not the most common problem with modern digital camera's.
Most of the time the problem is that sand , dirt and grit gets lodged in the camera lens barrel thus keeping it from extending properly but could also be caused by a drop or a hard knock on the camera.
Firstly , the odds are not with you on a DIY fix so don't be disappointed when the following steps do not work.Nevertheless , some people have fixed their camera's using the following steps.
Use these at own risk as it may further damage the camera.
Firstly try charging your batteries overnight and then try the camera again tomorrow.
Try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
These 3 options provide your camera with more power available to the extension mechanism which could overcome some of the particles that could be lodged in there if there are any.
Try using compressed air (best is a clean air can bought at a electronics store) and blow between the lens and the casing. This should help dislodge some of the particles.
Look at the lens , and if some of the lens 'circles' are misaligned or not concentric then try wiggling it (while holding camera lens down) so that some of the particles can escape. Also try moving the lens away from the side with the biggest gap (also upside down)
Try gently pushing or pulling the lens when it tries to extend but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
As a last resort if you decide to replace the camera try hitting the camera near the lens with increasing force with the palm of your hand. Between each hit , try using it again.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
I think Kodak charges about $100 flat rate to repair this error. If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise works. Good luck and don't hesitate to contact me if you need further assistance or information.
Regards
Stephan
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kodak EASYSHARE M340 Red 10.2
Questions and Unsolved Problems for Kodak EASYSHARE M340 Red 10.2
Do you recommend Kodak EASYSHARE M340 Red 10.2 MP 3X Zoom Digital Camera - MSRP: $149.99 ?
Answer
Answer
the camera opens up and shuts down immediately. the lens comes out and tthen it closes
Answer
The Lens will not retract, everytime i press the on off button it simply flashes green for a second... (More)
Answer
We bought one and one day the image just went blurry. Before that it worked fine. There was no... (More)
Answer
Kodak M340 has a intermediate clicking noise when turned on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak EASYSHARE M340 Red 10.2...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
