Question about HP Photosmart 2575 All-In-One InkJet Printer
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
    President:
  • 4,402 Answers
Did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Posted on Jan 02, 2008
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
The error message is Oxc18a0001. What is wrong with it. I've turned the printer off like it said to do, with no change.
Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
May 06, 2011 | HP Photosmart D7460 Printer
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Error:oxc18a0206
- Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
Dec 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
Can print...ink system failure - followed process but it wont wor
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 8180 has error message Oxc18a0101
try to follow this instructions to fix the error: Hit * and # at the same time on your printer, then enter code: 123 press right arrow, then go to system configuration and press ok 3x. unplug power from printer and wait 2 minutes, plug the printer again and then it will all be back to normal. hope this helps. Good Day!
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
618 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
