Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
1993 GMC JIMMY FUEL PUMP
I WAS DRIVING AND ALL OF A SUDEN MY CAR STOPPED AND DID NOT TURNED ON WELL I CHANGE THE GAS PUMP, FUEL PUMP RELAY, CHECK AGAIN AND TESTED OLD AND NEW FUEL PUMP THEY BOTH WORKED KNOW MY CAR WILL NOT TURN ON?
  • forsakenmace Oct 06, 2008
    I have the exact same problem, what the hell is it? its driving me crazy!!!
    -Raul
  • 26 Answers
Check for fuel, spark, and compression. if you have fuel and spark, but low or no compression its an internal issue.
Posted on May 09, 2008
Check your #1 plug and see if you are getting spark my be the distuberter cap or rotor is bad
Posted on Dec 25, 2007
2001 gmc jimmy wont stay started
check the fuel pump relay, some gm vehicles default to the oil pressure switch if the FPR fails.
Mar 17, 2013 | 2001 GMC Jimmy
I was driving my 98 GMC Suburban and all of a suden the engine died. I tried to start it but it wouldn't start. I turned the key to listen for the fuel pump and it sounds normal as it was pumping. What...
If no fuel is getting to the injectors replace the fuel pump relay. The engine oil sensor has a 3rd wire that sends the signal to prime the pump as you may know. When the oil pressure is reached to the normal range the computer shuts off that circuit to the oil sensor and turns on the relay to the fuel pump
Jun 30, 2010 | 1998 GMC Suburban
1997 GMC Jimmy has no power to the fuel pump. Is
fuse in the fuse box. also the power to prime the pump starts at the oil pressure switch. check that out too. then the relay for the pump in that order
Feb 18, 2010 | 1997 GMC Jimmy
1995 GMC Jimmy
The fuel filter may be dirty and not permitting the proper fuel flow, or the Fuel pump may have gone bad. If you turn the ignition on with the window open or your standing out side you should hear the fuel pump pressurize the fuel line for 3 seconds. If you think you didn't hear it you can try  again. If you do not hear it check the fuses to the ECM and Fuel pump. The fuel pump relay is in the glove box behind a panel that say relays. there are three of them, switch the relays around to make sure the relay did not go bad and i think the middle relay is the one for the fuel pump. The last thing would be to check is the fuel pressure, there should be 60 to 65 PSI when the system is pressurized and you can check that at the shredder valve on the fuel line towards the rear of the engine on the drivers side.
Ok lets recap, Check and listen for the fuel pump, if you can not hear it check the fuses and relays. oh and almost forgot there is a wire harness from the frame to the gas tank on the drivers side that may also be corroded, check for loose connection.
If you can hear the fuel pump, change the fuel filter and check the fuel pressure at the shredder valve, your going to have to rent a fuel pressure gauge to connect to the shredder valve. IF you want to save some money, just change the filter and if that did not help then check the fuel pressure.
Good luck and keep me posted
Jun 03, 2009 | 1993 Eagle Vision
Wont go over 35 mph
had that problem with a ford LTD years ago. Turned out to be the muffler. The baffles inside were loose and would block the exhaust flow as it increased with higher speed. Hope that helps.
Apr 27, 2009 | 1993 GMC Jimmy
I need to find and change the fuel pump relay on my 1993 GMC Safari. Any help?
relay is under hood in plastic fuse case, look at scematic for relay location in the case
Apr 18, 2009 | 1993 GMC Safari
Engine cranks, won't start. Three days later, it starts???
probaly a fuel pump its common for vehicles to do that the best thing to do next is a fuel pressure check to verifiy its the pump
Apr 15, 2009 | 2000 GMC Jimmy
Fuel pump blowing fuses
replace the fuel pump relay, it is burned closed from the shorted fuel pump.
Apr 13, 2009 | 1993 GMC Jimmy
Engine stopped while driving
Check your Fuel Pump Relay and Fuel Pump + Change the Fuel Filter. Should get you going again. Please Rate My Response! Thanks!
Feb 02, 2009 | 1996 GMC Jimmy
Car Audio & Video Logo
237 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
