Question about Dryers
How do I get to my heating coils in my whirlpool dyer model WED550SQ0, from the back or the top
  • 5,911 Answers
The heating circuitry for this model dryer is located in the rear of the dryer. Simply unplug the dryer and remove the exhaust vent hose. Loosen all the screws around the perimeter of the rear panel and remove. The heating element will be located on the right hand side inside the heater box. On the outside of the heater box will be two components, the Thermal Cut-Out (TCO) and the Hi-Limit Thermostat. The TCO will be located on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. These two components work in conjunction to regulate the temperature of the heating element. Both these components should read 0 ohms if good. If one of these components goes bad, you must replace BOTH of them at the same time (replacement kit part number 279816). Failure to do so can result in premature failure of any parts you replace. The heating element will read 9 to 13 ohms if good. The reason I mention this is because many people assume they have a bad heating element if the dryer does not heat. In the majority of the situations, however, it turns out to be a bad TCO.
NOTE: Make sure you take all resistance checks with the dryer unplugged and the components leads disconnected to isolate from any paralllel resistance paths.
If you have any questions, please let me know. I hope this helps you. For more information, you can refer to this link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you've already determined you have a defective heating element, that is great. I just wanted to include this information just in case.
Posted on Oct 07, 2009
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
DOESN'T HEAT
Could be bad heat element. Lift top of dyer, or look from back side with access panel removed, or look thru door if glass door while dryer is running on a heat cycle. You should be able to see red glow of heat element coming on. If not then you will need to open up dyer and remove drum. Inspect heat element for break in coil or coils touching each other or metal frame of dryer. You can also use an ohm meter and read the restence of the coil ...should be just a couple of ohms.
If it is a bad coil you should be able to replace fairly easy. If it is not coil than you will need to check themistor or cycle control switch. Hope this helps.
Nov 10, 2012 | General Electric DHDSR46EGWW Dryer
Kitckenaid dyer KGYe6778WH1 Dyer won't heat
This is most likely due to the coils on the gas valve, they can become unstable and cause the symptoms you are describing. The coil kit is part number 279834 and runs about $20.00. It is replaceable from the front and not too hard to do.
Side note: the '8' in your model number is actually a 'B'
Apr 22, 2010 | KitchenAid KGYS850LT Gas Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Dryer not heating up
Hi, If the dryer stops heating later in the cycle, it is most likely the coils on top of the gas valve. It is a very common issue with the gas dryer.
Here is how to change the coils
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 21, 2009 | Roper RGX4634KQ Gas Dryer
Whirlpool model #WGD5500SQ0 heats up, then goes cold and doesn't heat up again.
Hi, You will need to change the coils on top of the gas valve. They overheat and will not open the gas valve.
Here is instructions on get to the coil.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
Thanks
Vic
Jun 01, 2009 | Dryers
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
LGR4634EQ1-DYER WILL NOT HEAT UP
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Nov 15, 2008 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
602 people viewed this question
Top Dryers Experts
